Question about Gateway 560GE Intel Pentium 4 531 3GHz / 512MB / 250GB HDD / DVDRW Dual-Layer / Flash Medi PC Desktop
I need the wiring diagram for a G-way 560GE
My G-way has been without sound for several months. It says there is not a sound card. It has a black square attached to the motherboard. I decided to try and fix it. I unplugged all the wires, some I colored coded. But i got lost and can't fix it now.Please help, With a wiring diagram I can get it back to working again. Thank You & God Bless You,
  • earle_diane Feb 03, 2010
    need the wiring chart
    Very much so thank you very much.
  • 2,567 Answers
Please refer to the following system board installation guide:
http://support.gateway.com/s/Manuals/Desktops/8508816/index.htm
Hope this helps.
Posted on Feb 03, 2010
  • 542 Answers
First you check whether you sound card drivers has been installed properly. For this go to device manager and check the sound card status. Also check any conflicts between sound card and other devices.
2nd: After the sound card status and confirm that sound card is working properly, then check the speaker connections. Also check the sound properties whether you have selected the mute option? remove the Mute selection will resolve your problem.
Revert back for more assistance.
How to make a pc power unit work without a motherboard?
There are two pins on the atx connector you need to bridge. You can wire a switch to the pins too if you want so you can toggle on and off. Otherwise, there is a guy on eBay (seller id: antronst) that sells a connector with the pins already bridged with a on/off switch and a resistor wired in to provide some stability for five or six dollars.
Here is a diagram. Make sure it is a standard atx power supply. Some old Dells had goofy wiring.
http://www.techpowerup.com/articles/other/22
May 16, 2014 | Intel Acbel Power Supply Supports ATX 12V...
Taotao atv ata-125d wiring diagram
well if your wires fried then your battery was around 20v which means your voltage regulator was bad. you need to purchase a new one of those as well. as for the wiring diagram, if the wires around the battery had been fried. are they intact or completely burnt without you being able to locate to which each wire connects to?
Aug 14, 2013 | ATVs
Pontiac vibe headlight socket wiring
black wire ground.need to let GM tech fix. you need electrical diagram.you can go online internet look for online repair manual look up electrical wiring diagram for 2005 pontiac vibe online manual may charge you a little just for month use or one year use.
Apr 04, 2013 | 2005 Pontiac Vibe
Need wiring diagram and what is the use the black pin?
I don't have a wiring diagram but the black pin is if your sound card supports 5.1 you would plug the black pin into the back hole on the sound card. If not, use the green pin (in the green hole) and the black pin would not be used.
Jun 18, 2010 | Altec Lansing AVS 500 Computer Speakers
Need wiring diagram for the 3.0001 sable
2001? May have one for $10. I'll look if interested
Jan 16, 2010 | 2001 Mercury Sable
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
What wires do i connect for my cd player? What colors connect?
here are the factory wire colors and what they do.
1999 Ford Escort
Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Mar 04, 2009 | 1999 Ford Escort
Monitor stays black. Says no video.
I'd try running windows in safe mode by holding down f8 at startup. If that ends up working it's probably a setting that is wrong. If all still remains black i'd look at testing another video card and monitor. Either one could be it.
May 30, 2008 | ATI RADEON X1650 Graphic Card
No sound comes out of speakers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
May 22, 2007 | Dual XDM6825 CD/MP3/WMA Player
Gateway 560GE Intel Pentium 4 531 3GHz / 512MB / 250GB HDD / DVDRW Dual-Layer / Flash Medi PC Desktop Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
