Question about JVC HM-DH30000U DVHS VCR
Rewinding causes loss of settings
When I rewind a tape the VCR does the rewind OK but then looses it's settings (clock and so forth) and turns itself off. Visible rewind does not do this. Is there an EEPROM reset of some sort or may it be something else?
  • Bob Hess Feb 07, 2010
    Thank you so much for the answer you provided. I had not thought about opening it up although I've done so in the past going back to my beta VCR days and cleaning the tape path. I even still have a working beta hifi unit, but I digress. I'm not sure about the sensor and the tape end or beginning because there is probably more oging on here. I was messing with the deck last night and noticed that it may be somehow tied to the tape counter. When I put a tape in that is not necessarily at the very start of the tape and play, then fast rewind, it'll go back to around the 0000 mark and stop, turn itself off zeroing out the clock. Last night it would even turn itself back on and then off again after the initial shut off after rewind. The deck has not had much use and was a demo at Circuit City when I purchased it 3 - 4 years ago, but has had this problem since I got it. Should have sent it in under warranty, but didn't. Anyway, any other thoughts would be appreciated.
    Thanks,
    Bob
  • Philip Frye May 11, 2010
    Does this deck reset itself at any other time?
  • JVC Master
  • 5,807 Answers
It is normal for the counter to have errors on reading ( clock counter )
during rewinding.
Usually we use other ( separate ) Rewinders just for the purpose of
rewinding , and some have forward too.
Posted on Feb 08, 2010
  • Rommel Cana
    Rommel Cana May 14, 2010
    Usually we use other ( separate ) Rewinder just for the purpose of
    rewinding
    It lessens the burden or loads on the motors and gears.
  • 10,594 Answers
In my opinion, tape end sensor sounds defective or got blind for some reason that is why it does not detect end part of tape which is transparent to send center IR LED light towards end sensor. Check end sensor should be clean, or replace it to fix problem.
VCR turns off due to rewind error as tape reaches an end but motor still powering the gears because system control chip does not receive end sensor signal about tape end to stop motor, so it is an error and vcr shuts down.
VHS cassette (or any other recording cassette) has small transparent tape part at start and end of entire recording tape to provide IR LED light towards either start or end sensor.
IR LED is located right in center of cassette compartment.
Below image shows IR LED, start and end sensor locations, it is just an example to have an idea.
Let me know if you have additional question.
Thanks.
Posted on Feb 03, 2010
How do I stop my vcr (GE mod vg4258) rewinding when I want to stop it b4 the beginning of the tape?
Press "play" and then "stop". This will not hurt the player unless its tape transport systems are broken.
Oct 06, 2014 | Televison & Video
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Tape is stuck in the vcr and when you turn on the power it turns the tape about 10 seconds and then shuts off the power.
if the tape has snagged inside, the only way to get it out is to take the top of the vcr off and manually remove it. very simple procedure. only use your fingers and not anything sharp. have you tried rewinding the tape (from STOP mode) sometimes tapes can end up being wound very tight which would have the same effect. if you can rewind do so, then fast forward until tape stops, repeat this a few times this should loosen the tape.
Sep 21, 2008 | Televison & Video
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
VCR
Get thee back to the store. You have a defective TU reel sensor..accordianman
Feb 16, 2008 | Philips VR550 VHS VCR
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
JVC HM-DH30000U DVHS VCR Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
