Printer not printing
Have a Dell A920 All In One Printer. Have replaced both ink cartridges and the test run shows both inks working but documents will not print, paper is blank.
    Novelist:
    Champion:
  • 256 Answers
Issues in color printer are many. The most common one is the non-printing of color prints. This issue might be due to corrupted or incompatible drivers in your printer. When the driver installed in a color printer is corrupted or not installed correctly it might lead to issues. So in order to solve this issue you need to install or replace the corrupted driver with a new powerful driver; or reinstall the driver since the issue might be due to wrong installation of drivers. get more information to fix printer not printing error hope this helps you.
Posted on Jun 14, 2011
  • 4,041 Answers
Hi
There is a place in your driver when you go to print a docs there are some tabs there which will have Tools Tab you can clean heads from there, if heads not clean then try some tricks I used
Here.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
Run cleaning utility
  • Clean the Ink Cartridge Nozzles
    • 1 Load printer paper into your Dell A920 Printer.
    • 2 Open the Dell Printer Solution Center on the computer. Click "Start," located in the bottom left corner of your computer. Select "Programs" from the menu displayed. Click "Dell printers." Click "Dell AIO Printer A920" and then click "Dell Printer Solution Center" to open the Dell Printer Solution Center.
    • 3 Click on the "Maintenance" tab and select the option that says, "Clean to fix horizontal streaks."
    • 4 Click "Print." This will print a nozzle print page, which forces ink through all of the nozzles to clean and unclog them.
    • 5 Print a regular document again to see if the print quality has improved. Repeat the cycle up to two more times to improve printing quality.
  • Read more: How to Clean a Dell A920 Printer ' eHow.com http://www.ehow.com/how_6645628_clean-dell-a920-printer.html#ixzz1Dh2DMoc3
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 11, 2011 | Dell A920 InkJet Printer
    Dell A920 cartridge stall error.
    Hi, I HAD the same problem, but not anymore!! I just opened the top to expose the "inside of the printeri" and checked the long clear band at the rear behind the print head. Make sure that the clear ribbon is NOT TWISTED. There is a small metal bar with a small extended part on the far left interior of the printer. Just make sure that the slot on the clear band is fitted on that extended part. This will put the print head back "on track" This worked for me!!
    May 30, 2009 | Dell A920 InkJet Printer
    DELL PRINTER A920 PRINTING IS BLOGGIE
    Hi! Your problem is your printers INK CARTRIDGE alignment, make sure that your printer ink cartridge is properly aligned. Or try to clean your ink catridge. GOOD LUCK. THANKS
    May 06, 2009 | Dell Inspiron 1000 Notebook
    Hoirizontal white lines and poor quality in black and white print on dell a920 inkjet printer
    If you are sure your ink cartridge is not empty, it may be worth running the head cleaner a few times then print a test page.
    Worth a try for nothing.
    Good luck.
    Feb 23, 2009 | Dell A920 InkJet Printer
    White horizontal streaks in documents
    I Am Experiencing Poor Print Quality With My Dell™ Printer
    Table of Contents
    Verify the Printer Ink Levels Using the Dell Printer Solution Center
    Clean the printer contacts and print a test page
    Clean the Printer Nozzles Using the Dell Printer Solution Center
    Dell™ Printer Additional Information
    » Verify the Printer Ink Levels Using the Dell Printer Solution Center
    Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
    To check the printer's ink levels, perform the following steps:
    1.
    Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
    2.
    Click Dell Printer Solution Center.
    3.
    Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
    4.
    If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
    For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
    Back to Top
    » Clean the printer contacts and print a test page
    To manually clean the printer nozzles and contacts, perform the following steps:
    1.
    Turn the printer off and remove the power cord from the back of the printer.
    2.
    Open the printer lid.
    3.
    Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
    4.
    Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
    5.
    Lift up on the cap(s) that cover the ink cartridge(s).
    6.
    Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
    Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
    7.
    Re-insert the ink cartridge(s) back into the correct printer slot(s).
    7.
    Close the printer lid.
    8.
    Re-attach the printer power cord to the back of the printer unit.
    9.
    Press the Power button to turn the unit back on.
    10.
    11.
    12.
    Click the Maintenance tab.
    13.
    Click the Print a test page icon.
    A test page prints.
    Back to Top
    » Clean the Printer Nozzles Using the Dell Printer Solution Center
    To clean the printer nozzles and contacts using the Dell Printer Solution Center:
    1.
    2.
    3.
    4.
    Click the Clean to fix horizontal streaks icon.
    5.
    Click the Print button.
    Note:
    The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
    Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Flashing Green Light/ Computer can't communicate with printer......
    Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
    If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
    Hope this helps.
    Dec 14, 2006 | Dell A920 InkJet Printer
    Unable to print using black printer cartridge
    Well, Yeah mine did the same thing!!
    And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
    Then,
    Once you get home replace it with the others.
    BUY THE BLACK INK! not the TRI-COLOR!
    Sep 25, 2006 | Dell A920 InkJet Printer
    93 people viewed this question
    k24674
    jasbo
    jasbo
