Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Powersteamer problems Our powersteamer will not disperse cleaner or water. It is cleaned & lines have been checked for disconnection or crimps, but still nada. HELP
My power machine will not turn on
Posted on Jan 28, 2012
  • 701 Answers
You need to replace the pump belt. Here is the belt you need and it comes with printed instructions:
Bissell Pump Belt
Posted on Feb 04, 2010
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
Bissell Proheat will not disperse water. Any suggestions
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
cm
Aug 04, 2010 | Bissell 1698-1 PowerSteamer ProHeat Plus...
My bissell proheat wont disperse water
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 29, 2010 | Bissell 1698-1 PowerSteamer ProHeat Plus...
I need Bissell POWERSTEAMER® PROHEAT instruction manual
heatman101
hdf
May 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
beth
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Powersteamer 7901
I have a bissell proheat 9400 it is not dispensing the cleaner what can you do to fix it. Debra
Mar 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Mar 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
458 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
