Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
As I am sewing it will beep and I have to pick my foot up and start again. It will beep like every 10 stitches. the threading is correct, no needle broken, and it sews fine, however, it continues to beep throughout the project.
    Problem Solver:
  • 8 Answers
I just had this happen to me recently. The machine will beep if it senses any slack in the thread. In my case, the thread that feeds from the spool to the guides under the plastic disc was not all the way in. Re-thread the machine and pull forward on the thread as it passes the guide.
Posted on Feb 11, 2010
My machine does exactally the same and you have to keep taking foot off pedal do why?
Posted on Feb 06, 2010
Why does the stitches skip when I'm sewing?
Needle old or bent, incorrect size. Incorrect thread for material, packed with lint. The sewing foot is not on correctly or the needle is not pushed in high enough. Old thread. Hope this helps.
Aug 19, 2017 | Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
My machine keeps skipping stitches. I have had it werviced three times in the last n6 months, by two different repairmen, and it works for awhile, then starts backnup again. Any suggestions?
Usually, the first thing to try when a machine skips stitches is install a brand new needle. Also, be sure you are using the right type of needle for the fabric and thread you are using, ie ball point needle for knits, sharp needle for wovens, leather needle for thick fabrics/denim/leather... Needles do wear out with use, so changing needles frequently could be helpful. (Needles are the least expensive solution to most sewing problems!)
You can also try removing the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct.
10 reasons for skipped stitches
If the problem continues, it could very well be something within your machine that has not been appropriately addressed by the technicians.
Dec 29, 2016 | Sewing Machines
When I press on the pedal the machine just makes a 'vruuuuuu' sound, and when it sews it tangles around the bobbin! It also does not pick up the bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Damaged needle
8. Warped bobbin
9.First make sure the bobbin-winding spindle (located on top of your machine) has been pushed back to the left for sewing.
10.If it is not in the correct position, the needle will not go down and pick-up your bobbin thread.
11.Next make sure your needle is inserted correctly, with the flat side facing back.
12.Also, make sure your bobbin is in correctly
13.the upper tension disks of your machine are threaded correctly.
14.Make sure the presser foot is up when seating the thread through the upper tension.
15.Turn the handwheel towards you only and hold the needle thread lightly.
16.could be a timing problem
1611
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
Lever to control pressure foot will not lower foot
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?,,.
May 23, 2015 | Sewing Machines
Needle not picking up stitches
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? o
May 16, 2015 | Janome Sewist 525S Mechanical Sewing...
My machine runs but will not pick up stitch or skips stitches. how do i fix or adjust my machine so it will sew.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Dec 02, 2012 | Sew Pro ZZ401 Sewing Machine
Sewing machine not stitching
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
it's also possible that the machine needs to be serviced
May 31, 2012 | Singer Sewing Machines
The machine is threaded correctly, bobbin in correctly but it won't pick up the bobbin thread. The needle is not bent. It just suddenly started this. Please help!
Firstly please check that the needle is in the right way, flat shank to the back, and is fitted all the way up into the needle holder. This will affect stitch formation as the scarf at the back of the needle is where the rotary hook moves to catch the thread from the bobbin to form the stitches. A new needle never hurts either, should put in a new one for every new sewing project as they last only 4-6 sewing hours before they start to go blunt.
If this isn't the problem, then perhaps the timing is out, have you stitched into something, a pin or the sewing foot by accident to knock the timing out?
If so, time for a trip to the mechanic.
Mar 08, 2011 | Brother LS-2125 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
202 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
