Have a GE dvd player model GE1106P-B. It has a parental lock and it only 4 numbers. Is there a reset code for this player?
  • 44 Answers
Yes! Do you have a user manual for this player? How to specifically reset this feature is in the manual.
If you don't. I believe that GE has them posted on their web site.
Posted on Feb 03, 2010
My grandfather cant remember the code for parental controls. it is stuck on pg. can it be reset with out the code
Forgotten the parental control password? there is a way around this. According to the user manual (page 34) for this particular model:
Enter "788444" even if 4 digits "----" appears, then press [ENT]
to clear the current password.
Enter a new password and set the parental lock level again if required.
Note: DVD video discs may or may not respond to the parental lock
settings. Make sure this function works with your DVD video
discs.
You need the original unit's remote to do this. It cannot be done without it.
There is a .pdf of the user manual online.
http://tv.manualsonline.com/manuals/mfg/sanyo/dwm390.html
(It is free to download for personal reference in case you have lost your original copy.)
I hope this helps a tad.
Mar 07, 2011 | Sanyo DWM-390 DVD Player
My DVD player is locked, the display shows a red key.
Hi, This sounds like a parental lock issue. Try going into the set up menu and press the down key choosing custom by pressing enter (this is in the user manual page 20 - 22) then go down and select parental. If you know your parental control password code then enter it, if not the reset code is 4737 you will then need to create a new 4 digit code,There are 9 levels to choose from 1 - 8 and all, all being the selection that removes the parental lock. Hope this helps. James
Apr 21, 2010 | Sanyo DVW-7100A DVD Player/VCR
Cannot remember my parental control number is there an overide
try this:
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
Insignia parental lock code is on and do not know the code
parental lock codes are usually 0000, 1234, or the last 4 digits of your phone number
Jan 09, 2010 | Coby TF-DVD7333 Portable DVD Player
Does not recognize when disc is inserted
My model is a DPA-10040k and the DVD will not play a DVD and when it does it makes a weird noise and it ends up scratching the DVD. What can I do?
Jun 01, 2009 | GE Televison & Video
Sansui dvd san4312
DVD players don't need parental locks. When a user places a DVD player in Parental Lock mode, they usually create a 4-digit access code to remove the lock. Without the manual, I can't tell you how to reset to factory settings...what you need is either the access code or to reset it.
If it came direct from the factory with a parental lock already on, try the code "0000". If you need more digits, just use 0 until all of the slots are filled. If 0 does not work, try all 1s or 9s.
May 03, 2008 | Televison & Video
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
Feb 17, 2008 | Zenith DVC2200 DVD Player
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Dec 22, 2007 | GE 13V110TD 13 in. TV/DVD Combo
Parental control feature
if you can get to the operations menu page, after selecting on or off next to parental lock, press stop button four times then press enter this should clear the security code. press the number keys to create a new code press enter.
Dec 08, 2007 | Sansui VRDVD4005 DVD Player/VCR
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
