Question about Kenmore Dryers
My gas dryer is not heating up could this be the pilot light? Where is the pilot light?
    President:
  • 1,218 Answers
Good day,
Pilot lights were last used in the 1970's. The gas valve is fired off by a silicone carbide igniter. There are many reasons for no heat.
Here is a list. You need an ohm meter to perform some of these tests.
1. Make sure the gas is turned on to the appliance.
2. Remove the back cover of the dryer. In the center bottom is a small skinny white ceramic device, held on with one screw.
Remove one of the wires, and check it with an ohm meter. It should show zero ohms of resistance. If not, it is defective, and needs replaced. This device on your brand causes 80 to 90% of all no heat problems.
3. As well, there are 3 or 4 other thermostats in the area, either round or rectangular, with 2 wires going to them. Check all of them if needed. They should all check zero ohms.
4. To check the igniter, you will have to remove the front panel. A tutorial follows, on how to do that.
Locate the gas valve, on the left side. Follow it forward, you will see the 2 wires on a plug, and at the tip of the burner tube, the igniter itself. Unplug, and check the igniter leads. It should read about 20 to 30 ohms. if not, it has burned out and needs replaced.
5. On the gas valve itself, are 2 black coils, held on with a 2 screw bracket. They can fail, but cannot be tested with a meter. If they are bad, the heating system will light the igniter, and shut down without firing the gas. All components must be in place to perform this test.
That covers 99.5% of all issues. There are others, such as the timer, heat selector switch, centrifugal switch in the main motor, but are extremely rare.
The tutorial is not about heat trouble shooting, but is supplied to show how to gain access to the front of the machine. Kenmore is made by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Posted on Feb 03, 2010
Trying to light a new gas dryer. was unaware it was gas lol
Gas appliances normally require a pilot flame. This flame heats a thermocouple which operates the main gas valve when you want heat. The pilot flame may be out. Gas valves have a start-up process which normally requires you to press and hold the pilot flame button for up to 30 seconds (until the thermocouple heats up).
Your appliance will have been delivered with a user's guide in which you will find the pilot lighting procedure...OR...there may be a guide adjacent to the gas valve.
Apr 12, 2013 | Dryers
Hey, I am getting no heat out of my dryer, it is not the atlantis but is a gas dryer. I opened the bottom to see if the pilot is lighting and it is not. What do I do? The heat coil which lights the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
Gas dryer is not heating now.
That unit should have a glow plug igniter. No pilot. Please be carefull lots of lent to catch fire. Good luck
Nov 09, 2009 | Heating & Cooling
Dryer pilot light goes on then goes right out. dryer wont heat
Hi there. Soon as the pilot switches off (will still be red hot but fade away rapidly) the gas valve should turn on. (make sure gas supply is on) If valve doesn't turn on, check sensor located very near pilot element.
When the sensor "feels" the heat of the pilot, it switches the pilot off and the gas valve on.
Thanks
Paul
Jul 13, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
160 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
