Question about Maytag LAT3600A Top Load Washer
Agitator will not spin easily from pully below or
I am in the process of diagnosing the condition on my washing machine motor (belted maytag 15 years old) and the drag that the agitator presents to the motor. With the motor disconnected from belts, I have turned the motor on (spin cycle) and attempted to leverage it to a stop with a piece of oak 1"x1". The motor seems quite strong as I was unable to slow it down at all. Also, Agitator will not spin easily from pully below or from above. Is there maintenance that should be done to the agitator? Bad bearing?
  • 129 Answers
Transmission out buy new washer cost to great to repair 15 year old washer
Posted on Feb 04, 2010
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Tip
Washing Machine, Apliance help.
Washer works great during the wash and rinse cycle,the agitator works fine for those but the drum will not spin on the spin cycle. A couple of things go on when the washer goes from wash to spin, the motor pivots, tightens the belt and the drum spins up to speed. I had the same problem on my Maytag, I replaced the belt and the pullys and it has been washing and spinning great ever since, The belts can be accessed by removing the front panel, or disconnecting the machine and laying it down, if you see a lot of fine black dust,(rubber), the belt is probably worn out, change the pullys also at this time, it is cheap insurance that everything will go well. make sure that the motor pivots smoothly, if it does not, correct this issue first and run it. That may solve your problem, A great website that i use for parts and info is www.repairclinic.com. They have parts diagrams for tons of appliances, and stock parts, I have used them many times in the past.
on Jan 04, 2010 | Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
MY MAYTAG WAS SPINNING BUT SLOWILY. NOW IT WON'T SPIN AT ALL. THE LID SWITH IS GOOD, WHAT ELSE COULD BE PROBLEM?
it could be your agitator troubleshoot the following to isolate the problem: Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel. 2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator. 3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor. 4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt. 5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring. 6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Feb 15, 2011 | Maytag Performa PAV2200
Machine will not agitate or spin. Have replaced broken drive belt but machine only washed one load and now the motor just hums
hello it sounds like you have a frozen motor have you tryed spinning the pully by hand to see if you can spin the motor ? if your able to spin the motor pully by hand and it still is'nt turning when powerd on then your have a bad motor
Apr 05, 2009 | Maytag Performa PAV3200
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Squeal that sounds like belt spippage
The motor slides back and forth so there is know way to tighten the belt.The new  belt is needed if your old one shows any ware or if has shiny look to it which would mean its been getting hot and slipping.
May 16, 2008 | Maytag Legacy Series Top Load Washer
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
May 19, 2007 | Maytag PAV2300 Top Load Washer
Maytag LAT3600A Top Load Washer Logo
167 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
