Question about Amana ARDS802SS Electric Kitchen Range
Double burner not working. The left front burner only works on the "bigger" option and is taking a long time to heat up. The smaller burner isn't working at all. The rest of the burners appear to be fine. Thanks!
    Brigadier General:
  • 3,917 Answers
Hi
usually the only time the burners will not get hot is because you have lost one line of the power to your stove...if you have fuses one fuse is bad or plug-in is bad or cord has one line burnt off where it connects to back of stove...if you have breaker one line or side of breaker might not be working or any of the problems above might be wrong, will your oven heat up...if yes then the power wire to burners is bad...if no then bad fuse or breaker or bad cord or bad plug-in....
Do you have 240V to the oven? If there is voltage, Unplug the oven and remove the rear panel to see if a wire has burned off from one of the switches or not . It would be either the red or black (L1-L2)
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 03, 2010
Why doesn't my double burner work?
i wouldnt be surprised if its not the resistance for the lower temperature ,now as to if its in the knob or a electronic controlled resistance i would have no idea ,its not the element i wouldnt have thought as it should have a resistance but yes its possible the element has two windings in it best thing to do is to ask in the spares shop as they will know straight away
Jan 19, 2012 | Kitchen Ranges
Frigidaire Gallery Range (New). When plugged in, get a PF20 (power failure). Clock works fine. Both ovens work fine. Stovetop does not work. No heat in burners. No display over burner.
When it doesn't heat up,
We have a Frigidaire Range model PLEF398CCC and, as many others here have mentioned, we saw the puff of smoke and the oven nor the front left burner works. The repairman has to replace a EOC on the back of the control panel and another one in the back on the bottom. The total cost for parts alone is $438 then add in the service call cost. THIS IS THE SECOND TIME we've had an EOC go bad for big bucks. The unit is about 5 years old. We're thinking of filling the landfill with it.
Use this for troublshooting:
(home-electrical.suite101.com/article.cfm/troubleshooting_an_electric_range)
another testimony to help,
Had the same problem. This solved it for me:
(lazerangle.com/sanna/index.php?option=com_content&view=section&layout=blog&id=6&Itemid=63.).
Take care.
Jul 12, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Burner not working
This is an easy repairr and you can save a lot of money by doing this yourself. This sounds like your infinite switch burned your burner element out and you CAN do this!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7AM until 7PM CST and we will provide part removal/installation instructions when you purchase your parts through us.
We look forward to getting your range top cooking properly again soon, so call us when you need us.
Thanks, Ella :)
Dec 29, 2009 | Kitchen Ranges
Oven pilot light is on, but burners will not light. pilot light burns larger when trying to turn burner on. Do I need a new thermostat?
The thermostat is doing it's job if the pilot gets bigger. When you turn on the thermo, it does 2 things: Makes the pilot bigger and supplies gas to the oven safety valve in the oven. The bigger pilot heats up the bulb from the valve and the stuff inside expands and turns on the main gas. The oven cycles when temo is reached by making the pilot smaller. The most common problem is that the pilot doesn't get big enough to satisfy the valve. Take out the pilot burner ***'y. (7/16" wrench for the nut). Replace the pilot burner. The part is probably a 5414S030 if the valve bulb is located parallel to the ***'y.
Sep 30, 2009 | Magic Chef 31000 Gas Kitchen Range
Burner is on high all the time
Is this an older unit - 5 years or more in use? Sounds like the burner element is shot. Check the Amana web site for a replacement.
Bill B.
San Antonio
May 12, 2009 | Amana Cooktops
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Specs for burners for Amana AGS761W
that maybe that it's on the propane settings fron the factory on the regulator, and it's running on natural gas.Or if you see that the burners go smaller and smaller as you turn one burner after the other. if that replace the regulator. you can also get bigger flames when you make the orifises bigger. that's what supplies gas to the burners.
Dec 07, 2008 | Kitchen Ranges
One burner does not work. The outer burner works, but smaller inside one gets no power. It is only 2 years old
I called Maytag and even though my warranty had expired, they offered to fix it for free. What a nice thing to do!!
Oct 08, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Amana ARDS802SS Electric Kitchen Range Logo
50 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
