Question about Viking VGSC306-4B Gas Kitchen Range
Viking stove cooktop
One ignitor is constantly sparking ...the others don't spark .... can you help me ....
Service came out and said just unplug the cooktop and plug it back in. It won't fix it but it will work for.... beats paying 100's of dollars. I wish I knew this to save 85 $. I am going to replace it if this happens alot but until then I going to give it a try for a few times.
Viking has a major problem with this, read other posts. the service guy said alot less problems with wolf and thermador. I will never buy viking again, my cooktop is 2 yrs old with just general household use
Posted on Feb 21, 2008
Kitchen aid cooktop got wet wont ignight?
Usually Spark Switches might get shorted out or spark module went bad, but first unplug your stove and let it sit for a while (1-2 days) then try it again, if still nothing, then You will need to open up stove to check. Here is the video I made. Screws would not come off, so i had to replace almost all components on it. Hope It Helps.
May 28, 2014 | KitchenAid KFGU766VSS Cooktop
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Viking VGSC306-4B Gas Kitchen Range Logo
154 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
