Question about GE Washing Machines
I HAVE GE. MODLE #WPGT9360E0WW TROUBLE SHOOT MODE DOSNT OPERATE THANKS
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a GE DDE5100
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 04, 2011
I have a two wide line at the top and bottom of my tv picture. how do i get rid of lt? modle number dp37647-e-mail louisdyersr@yahoo.com
Sounds like you just need to change your display mode, look on the remote for a button that says zoom, also in your display menu with your remote, there also should be a setting that allows you to switch from standard widescreen etc. choose full screed or wide screen mode that should get you back to full screen, please keep me posted I would be glad to Trouble shoot this issue until resolved.
Jun 11, 2011 | Sanyo DP37647 37 in. LCD TV
Morel (GE) gsl25jftc bs frezer is icing up i have checked defrost heater el ement and has continuity, it coud be defrost sensor switch or defrost timmer how can i trouble shoot the last two comonents
it will be the defrost timer. If you manually forward the defrost timer it will click into defrost mode. This will melt the ice. The defrost termination switch will stop the heater once all the ice has melted.
If defrost does not happen then it is a faulty defrost termination switch
Mar 24, 2011 | GE Refrigerators
I have a GE DDE5100 electric dryer. On the permanent press mode there is no heat; however, on the regular mode there is heat. Looking to attempt to trouble shoot and repair. Thanks for your help.
heatman101
Jan 04, 2011 | Dryers
Dishwasher doesn't do a final drain. No water coming out of it just 2-3 inches of water still inthe bottom when it is done
sounds like a cycle timming problem. might be the pump but meh i failed that chapter test
check hose for food clogs and build up replace if exsesive wall cake is there since cleaning the hose usaly results in same broblem with in 1-3 weeks
{why dosnt any one include make and modle # when thy are seeking help?}
hope i helped
Dec 14, 2009 | GE Dishwashers
Lcd screen black.
try the disp button at the bottom, next to menu
dj
Apr 09, 2009 | Canon PowerShot S5 IS Digital Camera
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Hotpoint RB757WH1WW
Sheila, this is a electric oven. It's possible that your missing one leg of power. On the back where the cord attaches (terminal block) you should have 240V across the two outside terminals and 120V from each end terminal to the center terminal. You will have to see if you have that voltage. The clock will operate itself on 120V but the elements need the 240V. Also check your breaker box and reset the breaker. Check this out first...Catriver..post back.
Aug 26, 2006 | GE Hotpoint RA724KWH Kitchen Range
Washing Machines Logo
53 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
