I have a 35in t.v model cs-3505r made in 1989. picture starting to jump after its on for hour. if I turn it off for awhile its fine, then it start jumping again. Is there anything that I could do?
  • 44 Answers
Just to make you aware that this TV is 11 if not 12 years old.
With age comes issues with components such as the picture tube 'CRT' or more likely 'Capacitors' to which are drying out.
These are like small little batteries that over time just don't hold their voltage charge anymore. If it's rated for 9 Volts DC it's only charging to 4 of 5 volts at first. Over some time when the TV is on it might just get up to 7 or 8 volts and start to work again.
Unless you change all or know what specific capacitors to change yourself. Might be best to invest in a new flat panel TV.
Just a thought!
Blessings,
A/V Media Guy
Posted on Feb 03, 2010
Will a fob kill the battery on the bike?
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 01, 2014 | 2008 Harley Davidson FXDL Dyna Low Rider
1999 GMC Yukon turns over but will not start, there is a clicking sound, the check engine light came on the last time it started .
check code first get clue what next,could be crankshaft sensor,battery and battery connection.
Feb 28, 2013 | 1999 GMC Yukon
I have a 1995 isuzu trooper awhile ago my car wouldnt start cause i hit the alarm switch i thought i left it alone for awhile and it started. so today i went out to a store and went to start my car back...
Have the starter solenoid checked. With a continuity tester check if the positive terminal on the solenoid receives a signal when the switch is turned. If it doesn't then the switch is at fault.
Aug 23, 2017 | 1995 Isuzu Trooper
2002 Ford ranger starting
I had a similar problem with my old 1996 Mercury Sable. Turns out the problem was the Ignition switch was shot. Replaced it, problem solved.
That would be the next thing to check.
Mar 04, 2010 | 2002 Ford Ranger Regular Cab
1990 k1500 pu 4wd starts and runs fine but at times when you shut it off after running awhile it will not start, will not even turn over. let it set a few hours and it starts right up. Jumping the battery...
Sounds like you don't have a good ground at the battery. Take the clamps off of the battery and give them a good cleaning. Then, put some dielectric grease on the battery posts when you put the clamps back on.
Oct 03, 2009 | 1990 Chevrolet K1500
Anti theft related-car was jumped ran fine but won't restart after turning ignition-waited awhile it started but quickly died again and now won't start at all-tries to turn over but doesn't complete
What ever the matter was with it that it needed a jump start is probably the reason it started and died and now wont start. This doesnt sound like an anti-theft problem.
Aug 05, 2009 | 1998 Ford Explorer
I have a 20yr old cs-3505r picture tube just went out .
If the picture tube is bad (no likely), then the set is not worth repair. If you have no picture, it could be as simple as a bad horizontal Output Transistor or other simple component. In that case it would be relatively cheap to repair. If the picture was good before it stopped, perhaps it is worth the estimate charge at a local shop to find out the problem. Unless it is an obscure failure, the parts to repair it should be available generically and inexpensively. Keep us posted. Dan
Jun 12, 2009 | Mitsubishi CS-35305 TV
Fuel injectors
Make sure and change the fuel filter. Sounds like your problem is a fuel pump relay. Hope this helps. PHil
Jan 27, 2009 | 1989 Chevrolet C1500
Electrical
A. See web link at bottom of page. Some 1989 and early 1990 vehicles equipped with the 4.0 liter engine and automatic transmission may experience an engine no-start, hard restart, or an engine die-out. This condition may be caused by low signal strength from the Crankshaft Position Sensors (CPS) due to a larger than desired distance to the engine flywheel sensing ring.
What you need to do is check to see if the vehicle has a slotted crank position sensor. If the vehicle is equipped with a slotted crank position sensor, Figure 1, check to see if the CPS grommet on the top of the transmission bell housing has been updated,see Figure 2. If the CPS grommet has not been updated, replace the CPS grommet.
You'll need a Crankshaft Position Sensor, slotted, part number 83100067 and Crankshaft Position Sensors Grommet, dust cover, part number 83100068. When you install it, make certain that the CPS is completely bottomed on the machined lip of the bellhousing and is as close as possible to the flywheel sensing ring without contacting it. go to this web page for diagram: http://autorepair.about.com/cs/faqs/l/bl557h.htm
Jul 13, 2008 | 1989 Jeep Cherokee
Televison & Video Logo
Top Televison & Video Experts
