Question about Royal Office Equipment & Supplies
15mx large plastic gear has som teeth missing/ this gear also has a small metal pinion gear attached to it that has a few teeth missing / can it be replaced
    Genius:
  • 1,218 Answers
For parts availability and prices give Royal a call at 1-800-524-0799.
Posted on Aug 21, 2010
1970 Chevy El Camino starter broke teeth on flywheel. What would cause this?
several reasons
the teeth on the ring gear were damaged from continuous grinding during pinion engagement or engagement of the starter when the engine is running causing a burring of the teeth that altered the mesh ability and jammed the ring gear and pinion
metal in the teeth of the ring gear that causes a jam in rotation
starter motor not engaging before rotating
wrong no of teeth on replacement starter pinion or starter motor
Dec 17, 2016 | Chevrolet El Camino Cars & Trucks
Can you let me know what is the gear ratio for a 1995 isuzu rodeo. My rear differential is broken
Should be a metal tab bolted to rear inspection cover of differential displaying gear ratio or count the number of teeth on pinion (small gear connected to drive shaft) Divide number into the number of teeth on ring gear
Mar 22, 2011 | 1995 Isuzu Rodeo
The rollers will not go up and down anymore; looked inside and everythink seems intact
Your set up is most probably: an electric motor turns a worm gear that turns a large spur gear that turns a smaller spur gear that rides on a rack gear. The smaller spur gear (pinion) that rides the rack (yes, as in rack-n-pinion), allowing the up-and-down travel of the massage balls, has broken teeth which may not be visible because it's hidden under the larger spur gear. They are all plastic gears with lots of white grease.
Aug 14, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
Gear needed
Call 1-800-524-0799 at Royal for parts assistance.
Jun 03, 2010 | Royal 15MX Shredder
I have a 1991 dodge dakota that blew out the rear end, where can i find the gear ratio for the new rear end that i need?
I will assume you are missing your id tag. You will need to remove the rear cover and count the teeth. If you have never opened a drive axle I will warn you it will most certainly stink.
Now to figure the gear ratio:
The best way is to count the teeth on the ring gear and divide by the number of teeth on the pinion gear. Or you can count the number of turns of the pinion it takes to get one full turn of the ring gear.
For example, if we divide a ring gear with 41 teeth by a pinion gear with 10 teeth we find that the gear ratio is 4.10:1 (41/10 = 4.10).
Jan 14, 2010 | 1991 Dodge Dakota
Nylon gear has several of its teeth. 2 gears are
For parts advice call Royal at 1-800-524-0799.
Dec 10, 2009 | Royal 150MX Cross-Cut Shredder
How do I figure out the gear ration on a 4X4 front transaxle with the lable missing?
It will be the same as the rear. It the rear is missing you will need to count the ring and pinion teeth. Ring gear teeth Divided by Pinion gear teeth.
If you just want a ballpark idea, you can rotate the driveshaft and count how many revolutions it takes to make the tire go around once. That will be your ratio.
Sep 13, 2009 | 1995 Chevrolet K1500
I have a 98 Sunfire and it wont start?
Sorry about the theft, I know the feeling. You may want to take the starter back out and bench test it, Find out if it was assembled correctly (meaning is the pinion gear throwing out far enough) take a measurement from the pinion gear to the flange and compare it to the distance from the flywheel to the case. It is possible the starter is wrong too. Take a look at the face of the pinion gear and flywheel and see if the gear might be the wrong size.
May 31, 2009 | 1998 Pontiac Sunfire
Royal SC800 power shredder I need the large metal gear.
I have the SC800 apart. My problem is not fixing it. I just need the part. The large gear which appears to be made of pewter has a couple of teeth missing. If I could find the part I can fix it. It's a very simple machine. If you know where I can get the part I would appreciate you letting me know..
Sincerely;
Ken Ashley
Oct 14, 2008 | Royal JS800 Shredder
160 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
