Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
No water in dishwasher. When turned on all we hear is a clicking noise.
  • Whirlpool Master
  • 43,501 Answers
The problem you have here is the solenoid valve is either not opening or there is no water to the dishwsher. For more help check out this tip.
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Heatman101
Posted on Feb 04, 2010
Dishwasher has no water
Find out where your water supply is turned on to your dishwasher. Usually it is under the sink and make sure the valve is turned counter clockwise to supply water to the dishwasher. If this is on, on some models there is a float switch that will sometimes get stuck in the overflow position. Look in the bottom of the dishwasher tub and you will see a round float. Usually it is in the front left of the dishwasher. Move the float up and down and you should hear a clicking noise. Make sure float stays in the lowered position, closest to the dishwasher floor. Check those two and let me know what you find. And we can go from there.
Apr 01, 2012 | GE Dishwashers
TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
When first lets water in makes a very loud clicking noise. It still seems to be working fine otherwise. Later in the cycle the noise kicks in again. It's a slimline DE2541.
Two possibilities come to mind. One is that the noise is caused by a loose part in the solenoid valve. Another is that a foreign object in the water inlet is slamming into something when the water hits it. The dishwasher fills at least twice (for wash and rinse); that's why you hear it a second time.
Mar 11, 2011 | Dishwashers
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Dec 30, 2010 | KitchenAid 24 in. KUDP02SR Built-in...
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Feb 05, 2009 | GE 24 in. ZBD0710KSS Stainless Steel...
Kenmore Elite Dishwasher
I have the same problem...did you ever get an answer on how to repair
Apr 07, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
