Question about RCA HD56W66 56" HDTV
Rca hd56w66 convergence problem. ladywinn said it was a fuse where do i get replacement fuses?
  • Philip Frye May 11, 2010
    What's ladywinn as I know of no fuse that fixes a convergence problem with my experience.
  • 111 Answers
That tv has a convergence module and a convergence power supply it also has a block fuse on sweep module but i can promise you replacing a fuse will not correct your prob. the fuse is there for a reason if it opens there is a prob.but i dought its opened its located on sweep module there will be 3 block fuess in a row on the left side of the sweep module they are small red blocks good luck
Posted on Feb 04, 2010
  • redryder6994 Feb 04, 2010
    that tv has a convergence module and a convergence power supply it also has a block fuse on sweep module but i can promise you replacing a fuse will not correct your prob. the fuse is there for a reason if it opens there is a prob.but i dought its opened its located on sweep module there will be 3 block fuess in a row on the left side of the sweep module they are small red blocks good luck
Getting double vision and lots of color
hello, the most common problem with these sets is they loose voltage to the convergence board due to a fuse that opens up by the high voltage transformer, there are three brownish round fuses and one of them is bad and i use a pico fuse of the same amprage to replace it and have not seen any further problems with them. when looking at the back of the set they are at the left rear corner just to the right of the high voltage transformer. thanks....techman....580-243-8025
Apr 01, 2010 | RCA HD56W66 56" HDTV
I have a 56" RCA hd56w66 with a ITC222 chassis. My convergence is terrible. When I try to manually fix the red convergence in service mode, the upper left red lines are bent and will not move. Also my...
Problem could very well Be in your SSB board the one that connects to Deflection Board on Left side and convergence board mounted above it? When I get the time will do some more CK-ing on it, I have 2 of them Now that i need to get back into on repairing them,they also have wierd problems.
Oct 02, 2009 | RCA HD56W66 56" HDTV
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
Convergance can find in setup? missing
i suggest you read the fl231 fuse problem in the tips and tricks section of this website
Jun 06, 2009 | RCA HD56W66 56" HDTV
The convergence box keeps going out.
this 3d effect is due to what is known as convergence.i work daily on these set in the shop. (thats a good testomony for these LOL) but the first question i ask is 1 in the customer setup do you have convergence option.. Next question is the picture bow tie looking and 3d. if you are missing the convergence option chances are it is the fl231 fuse. then you need to read the fl231 fuse under tips and tricks section of this website. Convegence is controled by three cuicit boards. if any of these need to be replace a technician may need to set or adjust the convergence back to faactory specs
Apr 18, 2009 | RCA HD56W66 56" HDTV
My Television looks like 3D
if this is the fl231 problem look under my profile under tips and tricks section. there is a detailed instruction on how to repair the fl231 problem
Nov 11, 2008 | RCA HD56W66 56" HDTV
FL231 fuse on RCA hd56w66??
the rca itc222 comes in both 56 and 52 version.. If you do not have the convergence option in the customer menu under setup then there is a high chance that the fuse will be the trouble
Oct 02, 2008 | RCA HD56W66 56" HDTV
Convergence
Open Fuse FL231 will cause your problem.
Aug 06, 2008 | RCA HD52W66 Projection Television
Convergence
convergence next to flyback transfomer has 3 square like caps FL 231 is open most of the time it will cause lost of power as well as convergence.
Jun 02, 2008 | RCA HD56W66 56" HDTV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
RCA HD56W66 56" HDTV Logo
204 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
