Question about HP Photosmart 3310 Printer
After a few copies, I get a message that the black cartridge is empty. I replaced it once with a legit cartridge and after a few copies I get a message that the black cartridge is empty.
  • nancyellenf Feb 03, 2010
    This didn't work. Do you have anything else. Thanks.
    Master:
  • HP Master
  • 406 Answers
TRY CLEANING THE INK HEAD
Posted on Feb 03, 2010
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
How to use only black when the color is finished
you cannot use the printer by just keeping only 1 cartridge in the printer.as both the cartridges should be present in the printer then let the colour cartridge is empty what the problem is.you can print the black printouts with empty colour cartridge in the printer, but both the cartridges should be in the printer.and if still you get the message as colour cartridge is empty please replace the colour cartridge.the simple option is yopu can get the same cartridge refilled.as the cost of refilling is 10 times less then the new cartridge.
Oct 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Waste Toner for GP200 series
The waste toner is collected inside the drum cartridge. It can be emptied by removing the drum cartridge assy and opening the opaque window and emptying into a large bag. The lines on your copies are probably a symptom of the drum being worn out, so replacement is probably a better option. The drum is good for 60,000 copies.
Jul 17, 2008 | Canon IMAGERUNNER 6570 Copier
Empty ink cartridge message
I replaced the old cartridge with a new one (Magenta) and it still asks me to replace it with a new cartridge.
For 1 colour which is LOW, it stopped me completely from PRINTING or COPYING at all.
Any clues how to fix this?
Jul 11, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Dec 15, 2007 | Brother MFC 420CN All-In-One InkJet...
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Photosmart 3310 Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
