Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
My bosch diswasher won't empty, have removed cover and cleaned out the water dispenser as this was blocked and thought this might effect it.
  • 51 Answers
Have you removed the cover over the pump inside the tub that is secured with one screw?
email me if you cant resolve it. appliancesdav@hotmail.com
Posted on Feb 03, 2010
Why is my bosch exxcel7 emptying conditioner straight away even when machine is not turned on?
The dispenser tube is blocked and the liquid is syphoning out. remove and clean the drawer and the feeder tube / hole where the liquid runs out of.
Mar 01, 2015 | Bosch Washing Machines
Dispensing tray filing with water
If it is the tray for the softener that is staying full you need to remove the drawer and clean it. The pick up tube for the softener is either blocked or the piece that fits over it is not seating enough and this will stop the softener compartment from emptying fully.
Dec 29, 2012 | Bosch Washing Machines
My bosch classic xx diswasher is not emptying - what should I do
Recirculate/drain selenoid may have failed. Remove bottom kick panel and watch selenoid durind exhaust cycle. If it does not open to all water to empty, it must be replaced.
Jan 05, 2012 | Bosch Dishwashers
Washer finishes but hasn't dispensed softener. I've removed the tray and washed it thoroughly. Cleaning out the holes wiped inside of machine out checked the little holes they appear to not be blocked.
The softner is siphoned out by water effectively overflowing the area that you put it in. The tube is quite small, so it easily gets clogged with spilled powder. If you can take it out and separate it, tunr it upside down for a good clean too. You can get the effect by overfilling from the tap and the try should slowly empty.
Alternatively, you may not be sending water to the tray, so blocked nozzle (powder again) or stuck valve.
Oct 21, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Sep 13, 2009 | Bosch Nexxt 300 Series WFMC2201UC
The fabric dispenser does not empty
At the dispenser, remove and clean the cap that covers the tube in the dispenser tray, also clean the notch where the cap sits on the tray. The tube and cap work as a syphon, and something is not seated quite right. The softener is pulled out of the dispenser when water raises the level enough to start the syphonong effect. Once the water quits going into the dispenser tray, the syphoning continues until the level gets low enough for air to get under the cap, breaking the syphon. This usually leaves very little water in the dispenser.
Aug 10, 2009 | Frigidaire Laundry Affinity 3.5 Cu. Ft....
I have a Bosch WFF 1401. I removed the drawer as I sometimes do to clean it. Since I replaced the drawer the softner section is always filled with water and never empties.
There can be 2 reasons. The centre section dispenses the fabric softener in the last rinse. It works on a syphon effect.
If it is not assembled correctly the water flows over the side to avoid a flood and leaves the middle section full at the end. Make sure the inner pipe is inside the outer pipe and that both are completely clear of softener residue. As you have just reassembled it this is the most likely cause.
The second reason is the water inlet can become blocked therefore not creating sufficient flow to create a syphon effect. It gets blocked with black gunk and needs to be cleaned with pipe cleaners or a long cable tie. There are 4 rectangular holes above the centre section, near the front. They can be seen easily if you take the drawer out.
Hope this helps
Nick
Jun 24, 2009 | Indesit W 123 Front Load Washer
Bosch classixx washing machine softner dispenser fills with water will not empty
I have had this problem and found that it is due to not enough water getting into the softener chamber. THere are holes above the drawer in the inside that can sometimes get clogged up with muck, if you clean these out the water will flow and the syphon effect will work correctly.
Jul 20, 2008 | Washing Machines
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
791 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
