Question about Fisher and Paykel GWL11 Top Load Washer
Fisher n pakel won't drain
Washer runs through wash cycle but then wont drain then switch into spin
  • gcameron Feb 22, 2008
    after further exam found that the plastic impeller was broken
Pump Belt ?
Does The Timer Stop At Particular Position? If So, Timer Failure
Posted on Feb 20, 2008
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
WILL NOT SPIN/DRAIN CYCLE
Lid / out of balance switch faulty
Drip dry switch / button on
Sud save switch / button on
Apr 03, 2014 | Fisher and Paykel GWL11 Top Load Washer
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Jan 28, 2013 | Fisher and Paykel Washing Machines
My fisher pakel washer is stuck in regular wash, low water level. It sounds like the motor is emptying but it never goes to spin. I tried unplugging it to reset the computer but it always goes back to the...
Hi just just read your posting,Now have you tried selecting a different cycle and water level?Could you please confirm the model number of your machine for me.Is the machine draining the water out of the bowl? Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel washing machine is not draining or spinning what should I do?
The valve is stuck or dirt is in it. To fix blow in the drain hose of the washer about 3-7 psi enough to hear the air bubbles in the bottom of the tank, it might take more then one shot you can blow with the mouth but not with a air hose at 50 psi the valve and hose will not like it. It has always fixed mine, good luck. To check run in spin the last led red the water should run out.
Nov 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher & pakel eocsmart cycle but when it gets to rinse it starts beeping and wont drain the water
We had that problem and is was because we had the hose (which is long) too far into plumbing drain it would set off a syphon effect and stop. Then it would start the beeping
Oct 28, 2009 | Fisher Paykel EcoSmart GWL15
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
136 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
