Question about Polaroid FLM-323B Television
No signal Hi, I just bought an Insignia 15-in TV this weekend and every time I open it, a signal that says "no signal" appears on the screen. I have no clue what what do about this. Help?
  • mercurymars Feb 20, 2008
    Thanks for the advice, but I have neither a DVD nor a VCR.
  • pjake51 Mar 16, 2008
    I have a fairly new 37" lcd Polaroid FLM-373B t.v.. I have it connected to a DVD player and a separate VCR player. I have used it this way about 6 months and have had no problems with it prior. Yesterday I was watching vcr's tapes and then about 10 minutes later, without doing anything differently,I turned the vcr back on and clicked play and got a blue screen on my t.v.that said no signal. Nothing came on and I could hear the vcr playing. This went on all night, all day today. I thought it was bad weather but the cable is working on all of the other t.v.'s and vcr's in the house and there is no problem on any of the other t.v.'s. This is the only LCD t.v. we have and I wonder if you have ever heard of this before. I can watch any channel on t.v.,just get the dreaded blue screen when I power up my vcr connected to it. I have checked all the cables and they are plugged in tightly as before, and I can find no reason for this to have happened within about 10 minutes of watching the vcr. No signal is in the upper right corner of the t.v. I have also checked all of the connections to the t.v. I even un plugged the vcr and the t.v. and waited a while then reconnected and powered up. Same problem. Any help??? Pam
  • 2,334 Answers
Try connecting a DVD or VCR and use the video and audio from there to connect it to the audio and video input on your TV.
Hope this helps.
Posted on Feb 20, 2008
  • Jaime Hernandez Feb 20, 2008
    OK. Try to connect a small wire inside the Antenna input and search for any OFF air channels that maybe available in your area if you do not have cable or satellite.
Need manual for my tv,XVA133DLM-080507-01196
Product Support ' Insignia
www.insigniaproducts.com/support.html
Manual, Firmware, Drivers & Product Information. Most of ... For OPEN SOURCE SOFTWARE information refer to the on-screen display on your product. If you ...
[PDF]English - Insignia
www.insigniaproducts.com/.../manuals/NS-55E560A11_11-0573_MAN...
manual, or otherwise listed by an independent laboratory as suitable for your TV. •. Follow all instructions .... NS-55E560A11 Insignia 55" LED-LCD TV, 1080p.
Oct 07, 2015 | Insignia Televison & Video
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Just bought a 19" Insignia LED TV. Specs of the TV keeps appearing on and off at the bottom of the tv. Don't want to keep seeing it. How can I make it stop?
If the actual specs of the television keep appearing, the television could be in demo mode. Demo mode is turned on when the television is being displayed in the store. Is this a display open box model? There is an option in the display or set up menus to activate or deactivate demo or store mode.
If it is not the specs of the television but rather the channel and program information you are seeing, you may be having a different problem. In this case it is a signal issue you are having, and the only way to remedy that is to connect the television to a cable/set top box with RCA or component cables or to install a signal booster. http://www.amazon.com/Motorola-Booster-484095-001-00-Bi-Directional-Amplifier/dp/B000066E6Y
Dec 01, 2012 | Insignia Televison & Video
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Mar 12, 2009 | Insignia LCDTV26 26 in. Television
Insignia ns-lcd15 no picture
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jan 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Do I need a convert box for my tv.
the screen is not as large as it could be......has black frame around it.....also need a instruction booklet
Dec 12, 2008 | Insignia 15 in. Flat Panel LCD HDTV
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
INSIGNIA TV SCREEN - BLANK ???
the pwr supply is not regulating properly what happens when turned on regulation starts to swing and ripple increases causing lines in image panel....john
May 27, 2007 | Insignia IS-LCDTV32 32 in. Television
Polaroid FLM-323B Television Logo
156 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
