Question about Bunn CWTF15-TC
Does no heat water hot enough
Does not heat water hot enough
  • 35 Answers
Thermostat adjustment is behind front panel (behind brew basket) on the left-hand side (usually) Work it up gradually otherwise you may risk boil over.
Posted on Sep 09, 2010
Household steamer not heating at all
Well, first thing, just hook up service water and turn it on so the water heats up. Leave it long enough for water to get hot. If water doesn't get hot like should, then heating unit is malfunctioning. If it is getting hot after a while, you pull the handle trigger and water comes out, you have to wait long enough for the hot water to get to the head/trigger for it to go into the nozzles. If it was working ok before, and you were waiting for the water to heat, then then it should be working fine. Tell me what is happening if you wait for water to heat and get to the nozzles. I'm right here at my computer and we can get this thing going if the heater unit is good. Regards, Rigger.
Oct 07, 2014 | Heating & Cooling
The water never gets hot when on normal settings
This time of year the water comming in the house is much colder and heater has to work a lot harder to heat 40deg. water than ot does to heat 70deg water in the summer time. its normal.
Jan 09, 2013 | Water Heaters
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Model 587.14134102 dishwasher is not cleaning well. Unpon checking it by opening it up during various cycles the water does not seem hot enough. The dishes are warm to the touch but not hot. How can I...
Does your machine take in hot or cold water. If it takes in hot water the element that heats and maintains the heat may be defective. If it takes in cold water the element is heating it but the thermostat is cutting out the element at too low a temperature. Normally dishwashers take in cold water and heat it to the required temperature, which would mean that the thermostat is faulty?
Feb 06, 2011 | Kenmore Dishwashers
Do you connect to cold water or hot
You need to hook that to the hot water line...often the dishwasher will work better if you even run water to the sink and get the water hot before starting the dishwasher....they will keep the water hot but do not have a strong enough element to heat cold water hot enough to do a good job for you...
heatman101
Feb 02, 2011 | Dishwashers
Water not hot enough. Supply water is plenty hot but washing water is not hot.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 12, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Bunn CWTF15-TC Logo
419 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
