Question about Dell 926 All-In-One InkJet Printer
Low ink levels after replaceing with new ink cartridges
I have replaced the ink cartridges in both the black and color. I still have the low ink level indicators on the printer and on the computer screen. As far as I know these were not refilled cartridges, the were purchsed from Office Depot. So far the printer is working correctly, just can't get rid of the indicators.
  • 4,041 Answers
Hi
Dell's Inkjet, All-In-One Printers ... cartridges have a sensor in them that cannot be reset.
Sorry
Posted on Feb 03, 2010
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Reset Ink levels for canon mx310
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Jan 31, 2008 | Canon PIXMA MX310 All-In-One Printer
Low warning annoying me
Dell's proprietary grip on its printers causes this message to appear with any non-Dell or refilled cartridge. The messages/ink filled levels will only be reset if you buy a new Dell ink cartridge or have a way to update their encoding strip.
The good news is that you can still use refilled cartridges just minimize the level warnings to the task bar and ignore them when they come up. Everything should still print fine.
Nov 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
310 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
