Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Digital display wont light up and machine is unresponsive to keypad
  • 98 Answers
You may not have power to the Selection and Credit Computer(SCC). For quick troubleshooting, while rotating the CD carrier with the gold lever, watch the Z LED on the SCC. It should be flashing. If not, suspect no power to the computer or defective computer. I repair Wurlitzer parts, please email for further assistance, tech@wurlitzer-ohio.com
Posted on Feb 19, 2010
    Scholar:
  • 195 Answers
Have you checked the power supply in your jukebox for any blown fuses or circuit breakers that have tripped?
Regards
Alan Hood
ami-man
UK
Posted on Feb 17, 2010
Screen cannot be unlocked usink keypad and screen unresponsive after turning on screen with power button ,
they say if you tap the pad twice firmly in the upper left hand corner this will unlock the pad! some hp's has a light button on keypad, you tap the lighted button twice firmly just as you do with out lighted button
Apr 03, 2016 | HP Computers & Internet
Totally unresponsive to key imputs; display shows ERR
With any type of digital device such as this, there is a motherboard involved. When the buttons arent working, in your case, the solution is that the motherboard is shot. You could try to open the device and attempt to fix it or find repair service.
Apr 12, 2008 | Olympus VN-3100PC Digital Voice Recorder
How do I repair the keypad / input buttons?
Unfortunately, you are probably looking at a better choice of replacing the microwave rather than repairing the one you have. It probably needs a new control board and those usually will cost almost as much as a new microwave just for the part and not including any labor you might have to pay someone to install for you. Sorry!
Aug 11, 2014 | Goldstar Microwave Ovens
NordicTrack C 900 Pro display is unresponsive
1) Adjust the reed swithc, see the diagram attached, clean, and tight the connector.
2) Tight the ribbon cable from keypad ,tight the display board connector vs lower board.
3) After you did this, run the software calibration for diagnose, troubleshootign in according with the instruction manual.
sincerely. God bless you
May 08, 2012 | Nordic Track NordicTrack C 900 Pro...
Keypads will not respond. Either can't turn on or
Possible power supply problem--low voltage from master unit or dead batteries at each switch. Good luck!
Jul 25, 2010 | Lutron Electronic Low-Voltage...
My chefmate 1050 watt microwave beeps nonstop for minutes at a time repeatedly. I must leave it unplugged to get relief. Also, the keypad is unresponsive sometimes.
Either the touchpad or control board is defective. If the ribbon cable was disconnected from the control board and the beeping stops it would confirm the problem. Since the keypad is unresponsive, that probably is the problem.
Jun 21, 2010 | Microwave Ovens
Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Dec 17, 2009 | Kenmore Microwave Ovens
Apex Digital 19" LCD wont turn on green light blinks
you can have a electronics repair done on this unit call 719 687 6997
Jan 14, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Key pad won't operate opener
Check to make shure the battery from the second unit is good because it was stored for a period of time ,make shure it,s installed correctly . and after installing battery press any of the buttons you should see the keyboard light up , if you have a hard time seeing it because of the daylight just cup your hand,s around the display ! If that is all good then before installing the keypad on the outside jam ,go to the machine and locate the srt button or the smart button , after you located it just press it once and the yellow indicator light will turn solid , at this time you can program 4 digits into the keypad and hit the enter button on the keypad , At this point after pressing and holding the enter button ,you will see the machines lightbulb turn on and off once , that is telling you that the machine has just accepted the code ,for your other machine do not use the same code because the two doors will open togeter for example 1234 enter.................2nd machine 1235 enter you should have no problem programming the machines , theese are the easiest machines to programm and only take litteraly a few swconds each ....it takes me less then 5 seconds to do each ! also another way to check if your keypad is sending a signal back to the machine is find the srt button or the smart button (,they are the same button) look at the yellow indicator light next to it and then press the enter button and hold it down on the keypad you will see the light on the machine blinking rapidly , That is telling you that the machine is recieving a signal ! Good luck and hope this helps you , if your keypad still don,t work bring it back to sears for a replacement , sincerely Glenn
Oct 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
177 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
