Question about Dell 924 All-in-One InkJet Printer
I would like to replace ink cartidges in printer, but ink cartridges are not in place. I read the manuel and stated that it should move in position when I turn printer on unless it is busy. I dont know what to do. Help please
    Master:
  • Dell Master
  • 406 Answers
Put offthe printer and manually pull the carriage to the position. Then the inks can be replaced.
Posted on Feb 03, 2010
Cartridges won't move
turn off open cartridge unit and try to pull the whole print head. some units you can move only when off. if too hard then its locked. make sure cartridges are set correctly in place if it has a lid make sure its closed( for printer head not printer)
Mar 25, 2014 | Canon PIXMA Office Equipment & Supplies
Replacing cartdiges in sx 200 epaon
Press the ink button on the control panel repeatedly. This will work if at least one cartridge is completely out. With the scanner unit open, then the first press of the ink button will move the cartridge carrier to line up the empty cartridge with an "empty cartridge" mark on the printer. Each subsequent press will cause the next empty cartridge to line up with the mark. Once all of the empty cartridges have been indicated, the next press of the ink button will bring the cartridges into the replacement position.
If you want to change a cartridge when none are empty, you need to enter the Epson Toolbox (with the printer in a Ready state - scanner unit closed, etc). Then use the software to set the printer to change the ink cartridges. When prompted by the software, open the scanner unit and follow the directions for changing the ink cartridges.
If the cartridge carrier isn't moving when you press the ink button, look for anything blocking the path of the carrier. Even small pieces of paper could stop the mechanism. Use a flashlight to check the corners. (You may want to unplug the printer and try moving the cartridge carrier by hand to check below it.) Some models have the cartridge carrier run on a plastic strip that can come out of the guide on the back. Move the strip back and up and down until it is repositioned.
I hope this helps.
Nov 12, 2011 | Office Equipment & Supplies
My ink cartridges are stuck far over to left left and i can't move them
Power on the printer and lift the cover used to access the cartidges, the printer should then detect the door open and move the cartridges to a place you can access them. DO NOT FORCE THE CARTIDGES, you will wreck the motor...
Comment if you need more assistance.
Aug 17, 2011 | Office Equipment & Supplies
Load ink cartridges
Lift top lid, then scanner plate. Cartidges should automatically move to position. Gently push down on front of old cartridge to release it. Peel plastic tab frm back of new one(s). Put new cartridge in with front at downard angle. Lift front until new one snaps into place. Close lids.
Hope this helps
Dec 04, 2010 | Canon PIXMA MP210 InkJet Printer
PRINTER SHUT DOWN INK CARTRIDGE WILL NOW MOVE SO I CAN REPLACE IT I HAVE ALREADY UNPLUGGED THE POWER FROM THE PRINTER AND REPLUGGED IT IN
> cartidge will now move
If you mean will NOT move ...
Turn the printer on.
Open the cover over the ink-cartridges.
The carrier should slide to a position where the cartridges can be removed.
If it does not slide, then the belt that pulls the carrier is broken, or it's no longer connected to the carrier.
If all else fails, replace the printer -- try to find one that uses your existing ink-cartridges.
May 07, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Renewing ink cartidge
Turn the printer on. Lift up the cover on your printer. You will here the cartridges moving, then they will stop, in your case, i guess in the center, but if not, just look and you will surely see them (they may be either in the center or on the left or right end of the printer). Then just put your hand on the cartridge and gently pull down. You will not break anything, promise :)
Apr 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson SX200 Can't get the ink carrage to addopt change position
i had the same problem as this.
the manuel told me to put the ink in the printer before i had installed it, this however seems impossible.
instal your printer first. when it is instaled go to printer settings, then click on maintenance, then click on the option that says ink cartridge replacement. Follow the instructions and this will bring the cartridge to the change position!!
failing this you can unplug your printer quickly after you turn it on when the cartridges move, then you can manualy move into position. Not sure how good for your printer this is, but it works.
Jan 03, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge
followed the recommended procedure for changing ink cartridge,however although cartridge moved backwards and forwards it never stopped in the position to change it but remained under the housing on the right side of the unit
Nov 02, 2007 | Epson Stylus C40UX InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
