GS100 : Channel 1 cuts out briefly, then come
GS100 : Channel 1 cuts out briefly, then come back in. very intermittent, but always happens during church service.. any ideas
  • Audio Player... Master
  • 5,056 Answers
Two causes I think. 1 Bad soldering joint. 2 Dirt in a switch or volume control or other control that can be moved by hand. The option in this case would be to clean the switch/control etc with Servisol switch cleaner. Just spray it on the contacts or in the control.
I find Servisol Video 40 the best see image below:
GS100  :  Channel 1 cuts out briefly, then come - ab8a90b.jpg
Posted on Feb 06, 2010
Fender passport 150
The steps I would take to check it out are as follows:
1) Make sure that your computer isn't causing the issue - there are a number of software and OS issues that can cause spotty playback (do you have a lot of programs running at the same time? do you never restart your computer? does the cable fit in snug, or does it jiggle?)
2) Replace the cable connecting your computer to the mixer. If the computer is outputting properly, intermittence is almost certainly a cable issue.
3) If that cable doesn't solve it, try replacing the speaker cable. Though, if you're using more than one speaker and they both cut out at the same time, it's unlikely that this is the issue.
4) If you still are having troubles, it's probably a loose connection somewhere in the mixer. Contact Fender about getting it repaired.
Nov 06, 2013 | Audio Players & Recorders
Samsung LN-S3251D intermittent sound problem
Try to check the connection from your HD reciever it could be a loose signal from the reciever that why the sounds cut out..
Tell me more.
Thanks
Feb 19, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
My netgear wnr1000v2 router will intermittently not send a signal that can be detacted by my laptop
This usually happens because of interference. I've found the best way to deal with it is to change the channel on the router. Stick with channel 1, 6 or 11. It always works for me. Some months I change the channel once or twice.
Dec 27, 2010 | NetGear WNR1000 Router
Sharp Aquos E203 No Broadcast now
My LC46D64U just started doung the same thing for any over the air channel that starts with 6. It cuts out for a few seconds about every 60 seconds. Has anyone found a solution for this?
Jun 17, 2009 | Sharp LC46SB54U 46 in. LCD TV
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
Sony KP-53S15 Video only briefly during chan change
Sony KP53S15 blinks 12 times then powers up but had washboard or some call it louvered mutiple Vertical fold over? I think it is on the D board but some of my tech friends think its on the g board. I can't find any problem on either...HELP, I am pulling my hair out, I want my old big screen working again!
Nov 24, 2008 | Televison & Video
Sherwood Amplfier
Sounds like you like your music like me... LOUD. If you've done this a number of times, there are a few things that can happen:
1. You've blown the speakers... but you've said it operates for 2 seconds, then cuts out.
2. You've damaged the amplifier modules within the amp and they immediately overheat upon power-up. Does the music come back like 5 or 10 seconds after the unit cuts out?
3. Thermal switch has malfunctioned and just cuts off the power to the amplifier modules as soon as it sees any heat.
4. If you've gotten the amp really HOT during playing, it's possible that it's as simple as the amp modules are only intermittently connected (fatigued/stressed or cold solder joints) at the on the PCB. Just resolder the connections of the amp module to the PCB. I've seen that happen numerous times and that's where I'd place my money.
Jan 02, 2008 | Audio Players & Recorders
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
53 people viewed this question
 Grubhead
Grubhead
