Question about Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher
Drain cycle will not turn off - even when all the water has been drainged. Also stays on when opening the door.
  • jim173 Feb 03, 2010
    The bottom overflow pan is empty as well.
  • mike sam Apr 29, 2014
    Possible drain(float) switch on all the time, disconnect the float switch wires and try again, if problem solved, then replace the float switch.. good luck
  • 51 Answers
Pull the machine out and tilt it back, water may pour out from under the machine, if it does, it indicates that the anti-flood device has actuated, thats why the machine is continuing to drain constantly. leak some where underneath is the problem.
pallesappliancerepairs.com
Posted on Feb 03, 2010
Washing machine water not draining even finished the whole cycle? ANYONE have same problem? please help, thanks
I have had this when over filled my washer, repeat spin cycle several times and eventually the water will be goneso the door will open. Note turn power off if the cycle is set by rotating dialor more water may go into machine
Oct 15, 2015 | Washing Machines
Water won't heat; door won't open at the end of cycle
sounds like your German washing machine is working rather harshly...the heating issue and door locking are separate ones..
Feb 26, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Tip
Door not opening in Equator / Hirundo (EZ3612CEE/EZ2512CEE/EZ1612V)
Door not opening in Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door in the unit is not opening it means that the unit has not completed the cycle selected or else there is something in the unit that has malfunctioned. In such cases if there are clothes in the unit, one tries to open the door by pulling the door handle which mostly results in breaking of the door handle and also the clothes in the unit cannot be removed
To avoid the breakage of the door handle and also the damage to the clothes you can follow the following procedure to open the door.
  1. Make sure that the machined is turned OFF.
  2. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  3. Turn the wash program knob to cycle no. 4 & advance the knob by 6 clicks in the clockwise direction.
  4. Turn the machine ON by pressing the ON/OFF Switch.
  5. You will observe that the machine starts draining out the water and also the drum starts moving ( goes into the spin cycle)
  6. Wait until the water is drained out of the machine, this can be understood by paying attention to the sound made by the drain pump when it initially starts draining out the water and once the water has been drained out.
  7. Once you are sure that all the water in the unit has drained out switch OFF the power.
  8. Try opening the door now, the door should open.
Once you have managed to open the door, it is advisable to reset the unit first before further using the machine. For the Reset Procedure Click Here
on Mar 01, 2010 | Washing Machines
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Wh60f60w1
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
Apr 28, 2013 | Washing Machines
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Oct 07, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher Logo
236 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
