Question about Xerox Phaser 8560MFP Laser Printer
Samsung ML-2510 won't print
I have had this printer for about 2 years, and it worked great. Yesterday I printed about 43 pages and most wasn't legible - ink. I read to first take out the toner panel (with handle) and shake it, as that might get a little more use out of the toner, before replacing that expensive part. I did so, and put it back in the only way it can fit; clicked into place. Now it won't print from my desktop or from my laptop. When I ask to print, it revs up like it's going to print, makes 2 revolutions like it's going to pick up the paper, then stops and nothing. I've taken the part in an out repeatedly. Turned it off ,on repeatedly as well as the computers. When checking status of job, it has said a couple times, printer may be turned off or offline. I troubleshooted their recommendations, and still nothing. It's plugged in, usb to either desktop or laptop. I've used 2 different usb cables - no result.
Any ideas would be so appreciated. Thank you
Valerie
  • 54 Answers
Try unpugging it from everything, and leave it unplugged for a couple of days. This sometimes reset's printers.
Posted on Feb 10, 2010
Samsung ML-2510 printer: how many copies should I be able to print at one time. After 100 copies the printed page has a faded streak down the centre. Does my printer need a cooling off period after so...
The laser printer "shouldn't" need a cooling period from printing. Sounds like you do a good deal of printing with it,. Depending upon the quality of the printer you may need to break down the number of pages per print and see if that works.,. however, my best guess is that it needs a real good and perhaps regular cleaning...
Best regards
Ck
Oct 21, 2011 | Samsung ML-2510 Laser Printer
Page prints, but jams, samsung ml 2510 and toner is smeared over page
Your toner might be faulty, also remove toner and clean place with a cloth. Look to see inside if their are any loose pieces of paper in machine.
Feb 21, 2010 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Samsung ML 2510
The problem is the heat transfer unit in the printer. The heat unit on the right side is either not heating up at all or not enough to transfer the toner to the paper. If the printer is still on warranty it needs to be repaired by a tech. If the printer is off warranty, it's usually not worth fixing.
Jun 03, 2009 | Samsung ML-2510 Laser Printer
Can't print envelopes
is this the first time you use word ?
if it is any of the newer version 2003, 2007. the printing of envelope is as follow:
open the word, elect tools>>envelopes and labels. type in the delivery address and return address. click add to document.
completed you letter.
whenyou want ot pin the envelope, hig light the delivery address on the document, file, pirnt, type in 0 (zero) in the pages box under the page range (in the middle of the popup, under the "curent page button).
Mar 26, 2009 | Samsung ML-2510 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 doesn't respond....
I solved this problem with windows xp but have yet to solve it with windows 7. what worked for me is hooking up the hp print server to my network switch and to the 2510. Then I installed the 2510 driver using the samsung exe and choosing NO when it asked about installing the driver without the the printer attached. The NO choice continues and installs the driver. Then run the HP printer wizard choose drivers on this computer when you get to that spot. Then choose the 2510 driver and finish up. You may now have 2 2510 installations and may need to delete the default one under printers and set the other as default. This worked on 3 different xp machines for me
Sep 24, 2008 | HP JetDirect EX Plus Print Server
Samsung ML-2510 will not print from MAC OS on Macbook
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
169 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
