Question about Brother MFC-440CN InkJet Printer
Printer message: Unable to Print
My printer Brother MFC-420CN keeps showing the message, "Unable to Print," after it completes the start-up cycle. I'm able to use the Scan and Copy functions from the printer, and have whatever I scan or copy from this printer, printed out immediately on another printer connected to my computer. But I still can not print anything on my MFC-420CN. I went online and found a free service manual for the model MFC58 and learned how to put the printer on maintenance mode. I was able to get an error code, but since the manual is for the model MFC580 I was not able to learn the meaning of the code. The error code is 5A. Please any assistance with this matter will be greatly appreciated. Thank you. I ham getting an "unable to print" message whenever I try to do anything, even turn the printer on. Prior to this there was a paper jam. What do I do?
  • emmatom Mar 04, 2008
    I have the same problem on my MFC-440CN printer. It was printing just fine and then in midst of printing it said unable to print A5. Not sure why this happened, what it means and how to fix it??please help
  • 832 Answers
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Posted on Feb 20, 2008
  • Alexander Malkoon Sep 17, 2013
    Really??? I had a 5A Unable to Print error and I just unplugged it, waited 2 minutes, and it worked just fine. . .!!!
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 18, 2008 | Brother MFC 420CN All-In-One InkJet...
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN
press menu then start b/k copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press start b/k copy: What two digit error code does the machine display? Post here again.
To leave the maintenance mode press 9 then 9.
Mar 07, 2008 | Brother MFC 420CN All-In-One InkJet...
This will be older problem
Unable to print appeared and I unplugged and plugged back in, IT WORKS! One time only. Then I gent the message unable to clean. It will scan to copy and print at random. Is this a mechanical problem?
Jan 30, 2008 | Brother MFC 420CN All-In-One InkJet...
Error message on my Brother MFC-420CN
press menu then start bk copy then fourtimes arrow-up button. Machine will switch to maintaenance mode. You may have to press start bk-copy. The machine will display an error code.
Error code starting with 4 is always a defective print head which needs replacing (except error 46: new waist ink tank needed).
In case it is another error code plz post here again.
Jan 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-440CN InkJet Printer Logo
620 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
