Question about Evga MB 115-K8-NF33-AX NF3-250 754 Motherboard
I've been building computers since 1992. Never saw this. My EVGA MB is in a BIOS loop. Boot .. beep .. EVGA Splash ... -Reboot automatically- Beep ... EVGA Spash ... -Reboot automatically. It's like a BIOS loop. Over & Over. Hit "Delete" to get in to BIOS, can hear it accept the keyboard command, doesn't care. Just loops.
  • davedial44 Feb 04, 2010
    As I said, veteran at this. I remember keyboard DOS commands to set-up a reformat:
    C:\format C:\ -u
    .. so I'm ahead of you in thinkining in this direction and ordered an Asus motherboard compatible with my video card (kinda expensive, 7900 .. last of the AGP line), Creative X-Fi Titanium with front of computer fiber optic output and digital and RCA inputs (for my Gibson Flying V and Gibson Explorer) .. and an EMU USB MIDI 2x2 interface (for my synthesizers and drum module)
    .. AND with the new motherboard I also ordered a brand new power supply with 50 watts more power than I had before.
    My question:
    What's the percentage, if you had to assign one, that a new ASUS M/B and a new, more powerful power supply, will FIX this problem once installed?
    Just your best guess.
    I suppose it could be the SATA Maxtor hard drive but it never even looks at the hard drive, ever. It just beeps, shows the splash, beeps and boots again. No gettin' in to the BIOS to change anything. No control.
    Just Loopin'.
    Gawd I hope it isn't the hard drive. New MB, PS was my best guess to remedy it. Your thoughts .. and thank you for your time on this. Truly, I needed the help, came here because I heard you guys were the best.
    JB
    New Motherboard .. New Power Supply
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Sounds like failure of one of the onboard power supplies. Look for swelled (top domed) electrolytic capacitors on the mobo.
    Brigadier General:
  • 10,406 Answers
Turn the computer off.
Hold DOWN the "any" key.
Turn the computer on.
When you see "keyboard error. Press Fxx to enter BIOS SETUP", RELEASE the "any" key, and press the 'Fxx' key.
While in setup, change the boot-order to "floppy-first".
Then, everytime that you boot, your motherboard will "grind" the 3.5-inch disk, looking for a boot-sector.
If it DOES "grind", then BIOS-loading has completed, and there's something wrong with the boot-sector on either the CD-ROM or the disk-drive, i.e., Windows "crashes" during startup, and reboots itself.
Or, press F8 when you think that your computer is booting from the disk-drive, to enter the "Windows boot menu". Try "Boot In Safe Mode".
Posted on Feb 03, 2010
CONTINOUS BEEP WHEN COMPUTER IS TURNED ON
To do this properly I need to know which model your computer is - is it an eMachines MB.NBK09.003 Motherboard El1850 Desktop S775 G41T-Ad ? I need this to try to establish the BIOS seller and version. You might try finding the BIOS version by (continuously) tapping the F1, F2 or esc key (or possibly another)immediately after you turn on. The "splash screen" that appears aftrer you turn on may have some lettering which tells what key to enter the BIOS.
In the absence of this information here are two suggestions
EMachines that beeps constantly and won boot up
if it is the above it is serious and the computer will need serious (difficult) repair, or main board replacement or whole unit replacement (by which I mean new computer)
The other suggestion was about the RAM not being properly in place, but I doubt this as this usually gives a different beep code
19.January.2016
Jan 19, 2016 | eMachines MB.NBK09.003 Motherboard El1850...
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
When I try to boot my EVGA P55V micro mother board all it just goes beep beep beep, repeatedly I'm using a EVGA e-GeoForce 9600 GT card nothing apears on my screen it doesnt even look like its booting, the...
that beep (1 long and 2 short) indicated your ram has problem, from your suggestion i can know that your ram was died, change your ram with new one it will solve your problem
Feb 25, 2011 | Evga P55V 120LFE651TR LGA 1156 Intel P55...
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
Emachines single beep
It may be necessary to enter the BIOS setup to disable the integrated video and/or turn on the PCI slot(s).
It varies but entering the BIOS setup uses one or more keys (sometimes Esc, sometimes F1) that are pressed right after power on. Check your user guide to see which key give you access.
Most systems aren't smart enough to do that on their own and you may have the system looking at two video processors at the same time and is unable to resolve the conflict.
Jan 14, 2009 | Dell Dimension 4300S (Refurbished)...
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Computers & Internet Logo
206 people viewed this question
Top Evga Computers & Internet Experts
Tony
Matthew Spark
Matthew Spark
David
David
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
