My philips 32 inch tv which is fifteen years old the tv works and then it cuts the video goes but the audio stays on then it will come back and then the video goes and becomes a black screen i know the tv is old but first time i had problems thanks
  • hopper664 Feb 20, 2008
    thank yu very much probably time to buy new tv but is served is purpose but i will see how much it is thank you and have a nice day
  • 5,138 Answers
Your flyback transfomer may need to be solder around pinns or you have a bad capacitor in high voltage circuit.ThankYou for trying FixYa. Have a Nice Day. Call the repair shops see what they would charge to fix it.
Posted on Feb 20, 2008
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
Philips tv black screen
Check and replace the back-light inverter board. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 28, 2014 | Philips Televison & Video
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
Philips 7 year old 32inch cuts off while a high pitched buzzing sound stays until the tv is switched off at the mains
IF PICTURE PULLS ON RIGHT ADJUST BRIGHTNESS AND AND TINT UNTIL SCREEN SHOW FULLY AROUND PICTURE
Apr 04, 2009 | Philips 32PT5441/37 32" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
