Question about Executone 64 Corded Phone
Change display name on Executone 64 LCD
How do I program a different display name on the LCD for an Executone 64 phone extension?
SOURCE: EXECUTONE MODEL 64 Phone
quick way is to delete them both and re-record
Posted on Aug 09, 2007
  • 10 Answers
SOURCE: Executone 64 Administrators manual
if you can get into the programming then first go to the B screen and then press A and set the drop pulse to 10 and then press C for Copy and then Y .
hit ESC and press J
the cursor should be blinking on the first line on top left corner, there hit F for Flash and press ENTER
Hit ESC and press A , put in the EXT you need to program the key for, then press Enter, then K, then K again and pick a key to programm. once you have picked one by pressing ENTER key to move the cursor program a code 815 ENTER, S for Subcode and then 1 Enter
ESC, ESC E for exit.
contact me for more info
Posted on Dec 07, 2008
SOURCE: How do you change the date on executone 64 phone?
Step 1: Press Menu key
Step 2: Press Park 3 key
Step 3: Enter password followed by # key ex. 543#
Step 4: Enter 9819
Step 5: Enter date with # in between. Ex. 01#26#2009#
Hopefully this will solve your problem.
Posted on Jan 26, 2009
SOURCE: Executone 64 System: Only certain extensions ring
http://www.executonesystems.com/documents/IDS_UserGuide.doc
Try going to this user guide and see if this helps.
SOURCE: Executone model 64
In the event you haven't found this information, I got this from www.mainresources.com
To Change The Time
1.
Press the "Menu" key.
2.
Press "Park 3".
3.
Enter the password (default is 456).
4.
Press "#".
5.
Press "1" for System Functions.
6.
Press "4" for System Clock.
7.
Enter the time in 12-hour format.
8.
Press "#".
9.
Press AM or PM by pressing "Park 3" in the LCD screen.
10.
Press "#" to confirm.
11.
Hang up or press "HF".
Top of Page
To Change The Date
1.
2.
Press "Park 3".
3.
4.
Press "#".
5
Press "9819" for the date.
6.
Press the digit for the month (January would be "1").
7.
Press "#".
8.
Press the digit(s) for the day.
9.
Press "#".
10.
Press the digits for the year.
11.
Press "#".
12.
Posted on Feb 13, 2009
How can I change the system main greeting on an Executone Model 64?
from any phone dial 436 and then press #, then enter managers mailbox usually 5000 and the password, by default it is 5000.
then 3, 8 and 1# for CCR 1,(or 2# for CCr2 and so on) and follow the prompts
if you need additional help, call me. 2033955027. Joe
Sep 05, 2014 | Executone 64 Corded Phone
EXECUTONE 64800 PHONE, HOW TO PROGRAM STATION SPEED DIAL # 'S
from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Jan 09, 2014 | Executone 64 Corded Phone
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
Change the name on the phone display
Leave email address and I'll email you how....long answer.
May 12, 2010 | Executone 64 Corded Phone
How do you change the date on executone 64 phone? Our power went off & it reverted to Jan 1. I was able to change the time, no problem, but can't figure out how to change the date. Thanks!
Step 4: Enter 9819
Jan 26, 2009 | Executone 64 Corded Phone
Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
Nov 12, 2008 | Executone 64 Corded Phone
Phone in night mode
go to EXT 100 and program a key with a code 560.
you will do that by pressing the menu or F1 key and then fallow the steps for programming a key.
once you have programmed the key press it once and the display will start changing from night to day to holiday, pick the day and you are done.
Better yet, go to the phone that has on the display word NGT/night, or DAY, HLDAY and press the each key until the display changes that word on the display. one of the keys is programmed with key code 560. the phones that do not show Day, Night and Holiday will not have the key.
let me know if this does not work for you, or you need other help
Oct 07, 2008 | Executone 64 Corded Phone
hit ESC and press J
Apr 17, 2008 | Executone 64 Corded Phone
Aug 08, 2007 | Executone 64 Corded Phone
Executone 64 Corded Phone Logo
90 people viewed this question
Top Executone Lands Phones Experts
David Burbee
David Burbee
Tom Chichester
batMichael
Level 1 Expert
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
