How do I remove the outer cover to get to the motherboard
    Brigadier General:
  • 10,406 Answers
It depends on which desktop-case you have.
Look at the "back", to see if the side-panel "wraps" 1/2 around the back, where 2 to 4 screws are holding that part of the side-panel to the back of the case.
Unscrew & remove the screws.
Try to "slide" the side-panel "back" about 1 inch.
It should "unlock" from the rest of the case, and should become "loose".
Posted on Feb 03, 2010
Where is turn signal flasher on 2001 olds aurora
Hazard and Turn Signal Flasher Replacement
Remove the left knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gages and Console.
Remove the left IP endcap. Refer to Instrument Panel Outer Trim Cover Replacement
Gently pry outward on the rear edge of the IP outer trim cover until the retainers securing the outer trim cover to the IP retainer disengage from the retainer. Slide the IP outer trim cover rearward until the tabs on the front edge of the outer trim cover disengage from the IP retainer.
Remove the knee bolster compartment by pulling past the holding tab (1) and lifting up.
Unsnap the knee bolster by pulling down and rearward to remove from the vehicle
Remove the hazard and turn signal flasher module (1) from the I/P carrier. Disconnect the electrical connector.
Feb 12, 2015 | 2001 Oldsmobile Aurora
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
How do i get the outer cover off the cv joint on a xc berina
Have to remove the axle outer end from steering knuckle,
so you can do the boot
Jan 12, 2013 | Cars & Trucks
When i want to turn on my ps3 he always shows a yellow light. Sometimes he works but not for to long. only like 5min and then he falls back to yellow light...
It sounds like its Yellow Light Of Death its caused frome overheating and there is a break in the solider between the CPU and GPU. The fix is actually easy, but the instructions are a bit long I will post an answer from start to begining there might be quite a few.
Its called the yellow light of death. The fix is really simple, but the taking the console can be complex. So if you are up to the challenge hear it is.
Things that you will need: Heat gun, non-corrosive liquid flux (Found at stores like Fry's and anyplace that sells PC boards, also sold online at www.amozon.com), 1 tube of Thermal compound, 1 bottle of rubbing alcohol, 2 different sizes jewelers screwdrivers 1 small and 1 medium, Torks 9 screwdriver(Not necessary but helpful to get the 1st outer top panel off), Phillips No. 2, Phillips No. 1, and a tiny Phillips the size you would use for eyeglasses.
NOTE: Only the 80g consoles with the multi-port SD card reader on the front. These models will have the Blue-Ray ribbon cable accessible without having to pull power supply 1st. You will also have to pull the card reader and Wi-Fi/USB board from the front in order to remove the power supply, the only tricky thing on the card reader board is the ribbon cable connected under the PC board that connects to the motherboard it needs to be disconnected before the card reader board is removed. Also on these models for the removal of the motherboard you will have to remove the ribbon cable, PC board, and mounting bracket from the on/off sensor on the front right part of the casing. Once you have the motherboard and heat-sink out turn the unit over and on the HDD cage there are 2 small screws that have to be removed before you can separate the 2 of them. Looking at the back where all the cables hook-up, the plastic backing needs to separated from the motherboard. Turn the motherboard over and you will see on the plastic backing has little clips that you can unsecure by hand so it can be removed.
1. Disconnect all cords, cable, etc.......
2. Pull your HDD.
3. Pull the 2 outer top covers off.
4. After the 2 outer top covers are off, unplug the Blue-Ray player from the motherboard its front side on the left side of the deck. Lift the player slowly there is 1 ribbon cable on the bottom of it. Depending on your what model of machine yours, it will unplug from the motherboard either left side towards the back under the player or directly underneath the component to the left of the player. To disconnect the cable (using your finger nail) put the edge of your nail under the plastic locking clamp and slowly pry up and then slide cable opposite of locking clamp.
5. Remove the Wi-Fi board from off the front of the console in addition to that there is a black wire that runs from the Wi-Fi board to the back of the machine that you will need to unscrew.
6. Remove all screws that are holding the power supply down. There is also a yellow and green wire at the back that you will have to unscrew, next remove the plug from the back of the power supply, finally place the tips of your fingers under both underneath sides of the power supply and pry gently until the component unplugs from the motherboard.
7. Remove all screws around the outer edge of metal cover of motherboard.
Feb 21, 2011 | Sony PlayStation 3 40GB System
Ps3 turns on ok but then turns itself off after 30 secs
2. Pull your HDD.
SPECIAL SCREW NOTE: It makes everything easier if you separate the screws. I always separate by fine threads, course threads, and oddball. Also if you look close at where the screws come out you will notice a arrow telling you a screw belongs in that hole and any arrows that have a "M" by them that's where the fine threaded screws go, the "M" stands for machine.
8. After all the screws are removed around the outer edge, in the middle of the metal cover you can see 2 shiny plates and 4 screws, 2 screws per plate. Remove these 4 screws and 2 plates. Also remove the metal cover.
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Removing primary cover on 04 1200c
To remove the primary cover from you Sporty, you'll have to remove the shifter and foot peg. Then loosen the locknut for the primary chain adjuster and turn the adjuster downwards to loosen the primary chain. Then remove the plug at the bottom rear of the plug to drain the oil from the primary. Remove the clutch release mechanism cover from the outer primary. Remove the spring and locknut. Turn the clutch adjuster screw as far clockwise as you can turn it. Then remove all the bolts around the outside of the cover. While pulling the outer cover gently away from the engine, turn the clutch adjuster screw clockwise until the cover comes off.
Good Luck
Steve
Dec 18, 2010 | 2004 Harley Davidson XL 1200 C Sportster...
I installed a new wireless network card....when removing the outer cover of my pavilion xe734 a black and red wire came loose...it has 3 pins holes a white solid blank then 5 pin holes...i cannot figure...
if the wire is coming from the front bezel of the computer it sounds like your front panel connections. They connect to the motherboard and control your power button and lights. That would explain why it won't power on too! Unfortunately all motherboard connect to the front in different places, but it will always be on the outer edge of the board usually near the bottom of the tower. Try seeing which pins on the board match up. Hope this helps!
Jan 06, 2009 | Computers & Internet
Headliner Removal 2002 Dodge Dakota Quad
the visor clip is made in 2 parts. the outer cover needs to slide straight down which releases tension of the inner clip which is wedged in by the outer cover.
Dec 02, 2008 | 2002 Dodge Neon
Change a stator
First secure the bike on a lift. disconnect battery.remove standard footpeg.Remove standard shifter. Remove all allen head bolts from outer primary cover. Some bolts are longer so keep track of where they go.Two bolts on the primary inspection cover also hold the outer to the inner primary case, so remove the cover.Now remove the outer primary case.The clutch,primary chain,adjuster, and compensating sprocket must be reoved as a single unit.Once you have done this take a rag and grasp the rotor and slide it off of the main engine shaft.Unplug the stator and remove the set screws holding it in place.Reverse procedure to install new stator.
Nov 20, 2008 | 2003 Harley Davidson FXD Dyna Super Glide
Change a stator
Nov 10, 2008 | Harley Davidson FXDI Dyna Super Glide...
Computers & Internet Logo
David Payne
David Payne
