Question about Microsoft LifeCam VX-1000 Webcam
I have my webcam set on the monitor about 60cm from me and I can't get the microphone to pick my voice
  • 182 Answers
Actually the the webcam microphone have some limitation to pick up the sound signal from that much distance. better use new seperate microphone . try it, It will work, thats all........... I have my webcam set on the monitor about 60cm - kpfrlewajveq0aaaaasuvork5cyii%3d
Posted on Feb 03, 2010
Minicam pro ver.2 mic not working
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select
the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope it helps
Apr 20, 2012 | GE MiniCam Pro HO98756 Webcam
I have just brought a Logitec Webcam C120 and cannot get any sound. Do I have to get a microphone? When I do the sound test can't get any recording back.
Hi lynne_law ,
Many people mistakenly think that webcam can be used for audio as well as video transmission.
  1. Webcams don't usually come with microphones , therefore you would require a separate microphone for your voice recordings and voice chats.
  2. I would suggest you get a headset which would have the microphone option as well , or you can get a hand held mic.
  3. Once you get a new mic, you need to connect it to your computer by plugging in the mic in the appropriate slot , and by default the mic should work.
  4. If it does not work , you just need to change the microphone settings using the volume control option or audio settings via control panel.
Hope this helps ... ) Your feedback would be appreciated.
May 17, 2011 | Labtec Logitech 1200 Webcam
I have just purchased Logitech QuickCam E3100 - is there a microphone in this or do I need to purchase a seperate microphone or replace for a combined Web Cam and microphone?
Get a separate microphone, do not get a combo. This way you can position your camera at an ideal position and your mic as a perfect position to pick up your voice. combo units are nice because its one less thing but you will be unhappy with the results
Oct 04, 2009 | Logitech Webcam
IM PLus # 3500 Series Mic works one day but not the next. Video is fine, but mic isn't. I've looked at all the settings but the mic doesn't pick up my voice.
Several possibilities:
1. You may have inadvertently muted your microphone.
2. You may have multiple devices identified as the microphone, so that might be causing a conflict.
Multiple ways these might be fixed:
1. If you have a media-controller keyboard, look for a mute / unmute button there to see if that helps.
2. Alternately, open the Control Panel and open up the Sounds category. Navigate to the Recording tab and ensure you have identified the proper device.
3. Ensure your volume control utility for Recording has not checked Mute on the microphone.
Guessing you are using Microsoft product. Open the Control Panel
Sep 01, 2009 | Logitech Quickcam IM 961361-0403 Webcam
Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model. When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
Jun 15, 2009 | Acer Aspire One AOA150-1949 Laptop
IT DOES NOT WORK ECM-MS907 Professional...
Just in case you have having the same problem as me....
The reason why my microphone was giving mixed results was because I was using the wrong setting. The microphone slider says "90 degrees" and "120 degrees." I assumed that these angles refered to the area that the microphone picked up. So for a single narrow sound source, like my voice, the narrower, 90 degrees setting seemed appropriate.
Now that I have looked at the manual I see it is the reverse (weird but true. Perhaps the angles refer to the angles that the microphone ignores completely under each setting?).
I have been recording my voice. I noticed that sometimes the sound was good and other times the sound level was too low. I think that the reason is because sometimes I inadvertantly set the microphone to the 120 degree setting, which picks up my voice well, while at other times I set the mic to the 90 degree setting which attempts to pick up sound from a wider area, giving the central source less prominence.Setting the microphone to the 120 degree setting cured my problem. I hope it cures your problem too.
The manual is here:
http://www.docs.sony.com/release/ECMMS907.pdf
Aug 24, 2008 | Sony ECM-MS907 Professional Microphone
Microphone not working
Look in your system tray( next to the clock in the lower right hand side corner)
Locate the Volume Control and double click on it
Verify if the box by Microphone volume isn't muted
Good Luck
-John-
Dec 24, 2007 | Logitech QuickCam Pro 5000 Webcam
Acer aspire 5570 z series laptop computer
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and unselect Camera Microphone.
Click OK and it should be shut off.
Hope this helps. Bud
Dec 14, 2007 | Archos JBM Camera 100 - Hi-Speed Webcam
Voice does not work
You probably want to go into your Quickcam settings (audio) and make sure the microphone is set to the ‘Logitech Microphone.’
Nov 11, 2007 | Logitech QuickCam Messenger Web Camera
Microsoft LifeCam VX-1000 Webcam Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
