Question about Dell E173FP 17" LCD Monitor
Power light blinking. no other response - Dell E173FP 17" LCD Monitor
    Genius:
  • 1,011 Answers
The blinking LED mean that the display will not be shown to you and this problem belongs to short circuiting of transistor that are being connected with the mini transformers. The transformers boosts up the voltages for the LCD screen.
IF you are a technical person then handle the situation as i am going to describe. Otherwise, get it done by an expert in this field.
1. Open the back stand that holds the monitor by opening the 4 nos. of philip screws behind it as shown
2.After the stand is removed you will need to pry the back of the case off as illustrated in the pictures below. Use a small flat bladed screwdriver start at one of the release openings on the bottom as shown. Once you have a little gap in the case just pull the 2 halves apart and work your way around the screen.
3.
After the screen unit is removed from the plastic case we can get down to the repair. We need to remove the power supply unit. You will need to unplug the 4 back-light connections (connectors with pink and white leads, circled in red) and the control panel cable the flat signal cable. Then remove the 2 screws from each end, then undo the 2 small nuts holding thpower light blinking. no other response - 8cb60d4.jpgctor to the case (circled in yellow).
4.
Before you fully remove the shield and board assembly be sure to unplug the LCD signal cable that is under the boards as seen in the picture to the right. Now turn the assembly over and remove the 5 screws and the 2 plastic standoff clips as marked by the yellow circles below. Now with the board removed you will need to replaced the components that are circled. The parts are as follows:
3 Amp Fuse (yellow)
Q759, Q760, Q734 & Q740 - C5707 transistors (red)
Q743 & Q751 - MOSFET Transistors (blue)
The location nupower light blinking. no other response - ce75923.jpgr a E173FPb but the E172FPb boards have thepower light blinking. no other response - 94440e2.jpg in the same locations.
I hope it is an understandable thing to do. Get it done yourself or an expert and get back your view...
good luck
Posted on Feb 03, 2010
  • 1 more comment
  • SALMAN NASEER Feb 04, 2010
    If the VGA cable is problematic then the permanent orange LED will glow.
    regards,
    salman
  • chancemwalwa Mar 01, 2011
    You made my 1year trying to fix this a night in quatar plaza. You are another gig.Thanks
    Chance Mwalwanda-malawi
  • Lynn Kelley
    Lynn Kelley May 27, 2011
    whats the trick in pulling those 4 backlite connectors out they wont come out and I'm worried that I mite pull the wires out.
  • 182 Answers
Better check the vga cable of the lcd monitor, power cord also and install the vedio driver properly, if this is also not working better contact dell service center . power light blinking. no other response - kpfrlewajveq0aaaaasuvork5cyii%3d
No power button light loops blinking light on caps lock and chrg light
Here is a link to a other forum that has a view links for Toshiba laptop error codes if your laptop is not under these just tel me what your laptop model number is.
http://www.hardwareanalysis.com/content/topic/51345/
Dec 30, 2013 | Toshiba Satellite Computers & Internet
My menu pops up when changing channels?
Let me see if understand your question:
The Menu pops up when changing channel and power light is blinking?
Brand and model number are not posted here but a guess is the light is blinking in response to the remote---point remote at the set and when menu pops up power light may blink for an instant.
I would like to help but need more information.
click the make a comment button and tell me as much as possible.
Mar 24, 2012 | Televison & Video
Remote lights blink no response. All three lights on remote blink and no response from unit.
Fuses and/or power to unit is gone out. Find source of power and ground to unit and you'll find your problem.
Feb 01, 2010 | 2007 Toyota Camry
Power light on pc mv1214 laptop blinking but wont on
have you already got a solution for this problem?, please send me a message if you have, kindly send me at this email imalwayzme_md2008@yahoo.com... your response is highly appreciated.thank you
Oct 18, 2009 | Sharp Computers & Internet
TV picture went out. stand by/timer light blinks when I turn on the TV. no other response from TV.
The timer light blinks representing the fault on the tv. If the tv blinks in an orderly fashion then the number of blinks before pausing is used to indicate the fault. This can only be determined by looking at the service manual for that set. If the blinking is continuous without pauses after a number of blinks, then it indicates there is a problem and the first place to look would be in the power supply. Either the power supply isnt supplying power to the Line output transformer i.e an open circuit or short circuit..OR the line output circuit has a short. Without a diagram i cannot guide you which components to check..but..swollen topped capacitors in the power supply are a give away :)
Aug 02, 2009 | Sony Televison & Video
Blinking standby light
Have you fixed this yet?Please let me know.Thank You very much!
Tyler
Jul 09, 2009 | TruTech PLV1615T 15 in. LCD Television
Blinking power light no response
I had this same problem and took it in to have it repaired. They told me the transformer board had gone out. cost me about 650.00 to fix it. I hope this isn't the problem.
Jun 22, 2009 | Toshiba 57H81 57" Rear Projection...
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
Dell E173FP 17" LCD Monitor Logo
1,345 people viewed this question
Alun Cox
