Question about Xerox Phaser 6360 Laser Printer
Phaser 6360 DN Magenta smeared on all images
We already changed the aforementioned toner-no help. Any ideas?
  • 49 Answers
SOURCE: Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Posted on Mar 30, 2009
  • 79 Answers
SOURCE: Xerox phaser 6120 "magenta toner missing"
You're welcome. I will mark this as a solution.
You could try cleaning all the electrical contacts on your magenta cartridge. An Isopropyl wipe would work well.
It is also possible that the cartridge may have warranty for the life of the toner, worth investigating as they are expensive.
Posted on May 01, 2009
SOURCE: Phaser 6350 flooded with magenta toner
Problem developers start leaking toner. The problem is that some times the toner spuills into developers below it and damaging them. The problem may appear as a grinding noise that may indicate a developer gear/motor problem, when in fact its a bad developer that is not running smoothly. It may be expensive, and you may have to replace ALL the Developers.
Posted on Sep 12, 2009
  • 159 Answers
SOURCE: Xerox Phaser 6360 Black Toner prints Light Grey
I have had to repair a few of these. Take off the sides and back of the 6360. You'll see the hoses that feed into the laser. The black one becomes unplugged from the laser. All you have to do is plug it back in. The next step can be kinda messy. Take out the black toner cartridge, and spin the motor backwards. You'll know you're going the right way because it won't turn the other way. Cycle the gear where the toner sits for about 2 revolutions. Reassemble and you should be good to go!
This thing took me 6 days to figure out the first time. Haha!
Please vote on my solution! Thanks!
Posted on Oct 26, 2009
  • 3 Answers
SOURCE: the black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Posted on May 08, 2010
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Xerox 4620 is printing smears all over the page. I replaced the drum but it is still happening. Not sure what could cause this prblem
ask yourself this . Is the paper warm or hot when it has been printed on ?
check fuser unit .
No heat equals unbonded toner on paper equals smearing of toner on paper.
Oct 20, 2015 | Xerox Laser Printers 4620/DN Phaser 4620DN...
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
Jan 28, 2014 | Xerox Phaser 6360 Laser Printer
My printer is pringting magenta all over the page. What should I do? I have replaced the imaging unit, fuzer, and the magenta toner cartridge.
zach,
We are having the same problem with our Xerox printing magenta. Did you every solve this? If so, what was the problem?
Thanks - Paul
Feb 03, 2011 | Xerox Phaser 6360 Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
The black print jobs have a shadow about 3 inches down the page
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 is ghosting. replaced transfer roller but no help thanks Bruce
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Dec 16, 2009 | Xerox Phaser 6360 Laser Printer
I have a problem with ghosting on a Xerox Phaser 6360. Have replaced the Transfer Roller, Imaging Unit, and Fuser. It looks like the problem is mainly in Magenta. This is not a repeating defect, but a...
I have the same problem with whatever color that used most. The Xerox sent its people over to fix it. However, the problem gets after a few days. Probably, it cannot handle large volume.
Dec 02, 2009 | Xerox Phaser 6360 Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser  6360 Laser Printer Logo
196 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
