Question about Hand Tools
Is special tool # J-37763 the proper tool for front lock nut retainer nut for a 1998 tracker 2dr 4wd?It appears that this will be needed to remove this nut to get to bearings! so unless there is another way,I doubt this is the case i am thinking i will need this tool
  • 979 Answers
SOURCE: front wheel hub bearing 02 explorer
Three bolts is the easy part. You will likely have to have the old bearing pressed out with hydraulics and a new one pressed in....accordianman
Posted on Jul 29, 2008
alicantecoli
  • 22246 Answers
SOURCE: WHAT SIZE SOCKET IS NEEDED
32mm
Posted on Nov 24, 2008
SOURCE: 1999 saab 9-3 wheel bearing removal
You need air tools, many differnet size sockets and a press. The strut/spindle and lower control arm have to come out all together. leaving the axle in the car.The spinlde cannot be removed from the strut. once removed, you can then unbolt the lower control arm ball joint nut, and seperate the lower control from the spindle - for ease for the press. press the hub out, remove the snap rings on either side and press the old bearing out. press in new bearing , install snap rings, press the hub in and reinstall. I just did one today... I have 15 years experience as a ford tech - Ugh bro.. - Josh
Posted on Dec 14, 2008
  • 583 Answers
SOURCE: need torque setting for 1993 geo tracker front
i1m sorry to say that wheel bearings are not set to a torque specification, when you have repacked the bearings [ inner and outer ] ,reassembled it ,take the nut up until thewheel starts to drag and not turn very far when you try to spin it spin it backward and forward several times,grab the top of the wheel and try to push it in and out,if you getany movement at all tighten the nut a couple of castilations. do it all over again, spinthe wheel a few times and then try for the crossways movement again, if there is no movement ,you are very close to being right....................now comes the experience bit , iwould take it one more castilation of the nut because i know the feel that is need ed,,without that i suggest you put the pin in where you ereput the cap on and go for a 5 minute drive . whenyou get back ,jack it up and thespinning of the wheel again and try for the top crossways movement ,if there is any tighten thenut 2 castilations, and provided that when you try to spin the wheel by hand with a reasonably strong push the wheel should trael about 6 inches at least after your hand leaves it ,it is now a close as you are going to get itput it all to gether and for the next day or so put yor hand on the grease cap after you have driven anydistance, and you will feel it is warm but you should be able tohold your hand on the grease cap. there you have it ,any questions come back."youdoit"
Posted on Nov 06, 2009
AEpgh
  • 51 Answers
SOURCE: 1993 F150 4x4 w/ auto locking hubs - rotor removal
There are some special 4 tooth and hex sockets for removing the nuts inside the hubs of the truck.
YOu can find these at NAPA or maybe AutoZone or Advance. I would go to NAPA because they more than likely have it and also know something about repairing this assembly.
Ford uses Dana front end parts and NAPA has original Dana parts in stock... so it is as good as or better than original and they would have the tool for it.
Be careful and follow the procedure exactly for putting the front hubs back together.
YOU CAN RUIN THE FRONT END OF THE TRUCK IF YOU DO NOT PERFORM THIS SERVICE CORRECTLY.
And trust me... many of the idiots working in repair garages do not know how to do these older 4x4 hubs either... ask someone and read the books for the right procedure... some of the older mechanics may show you how to do it. Ask
Posted on Mar 04, 2010
How do u remove hubs on a 1992 Isuzu big horn
TO DO WHAT? not even the smallest hint on job or failure.>?
USA?
hubs, the rears have hubs to with disc brake option.rotor hubs.
I guess front hubs?.
guess 2, wheel bearing hubs, and not 4wd axle locking hub units.
doing what?
brakes, wheel bearings, axle damage. 4wd axle bearings what?
the pages are 2wd pages, and 4 wd pages, which is yours?
is this your first time DIY ever. ? or first time 4wd?
guess 3, 4wd, how am I guessing....
names
Acura SLX
Chevrolet Trooper
Isuzu Bighorn
Holden Jackaroo
Holden Monterey
Honda Horizon
HSV Jackaroo
Opel Monterey
Subaru Bighorn
Vauxhall Monterey
wow......
our usa book lists it as trooper only.
so ...
just B or B then A off? if you had b off, you'd see what?, a big nut.
that is locked to spindle shaft.
ill guess? wheel bearings are bad? (just in hub not spindle bearings bad... no matter this is first.)
so you do what. ? here are the steps.
that part"B" must be off first, see the bolts holding it, ?
B = auto locking hubs. or hub axle lockers.
26005769-b5pjo3cin0lhc1b54v4xlnuy-4-0.jpg you can see the caliber must come off, so, do so and tie them up.
  1. "Place the Transfer shift in the 2H position.
  2. Raise and support the front of the vehicle safely on jackstands. (rear tires chocked, and hand brake set hard)
  3. Remove the wheel and tire assembly.
  4. Loosen the hub to rotor retainer bolts.
  5. Remove the brake caliper mounting bolts and carefully remove the caliper (along with the brake pads) from the rotor. Do not disconnect the brake line. Secure the caliper out of the way with the flexible line still connected.
  6. Remove the hub nut using hub wrench J-29020-A or equivalent. ( special tool)
  7. Remove the hub cap assembly retainer bolts. Remove the spindle nut, washers, and other components. Remove the hub/rotor, being careful not to drop the outer wheel bearings. As the hub/rotor is pulled forward, the outer wheel bearings will often fall forward.
  8. Once the hub/rotor is removed, remove the retainer bolts securing the rotor and hub together. Inspect the hub and replace if needed."
  9. end removal. install is next... (alldata.com covers this)
Dec 13, 2015 | Isuzu Cars & Trucks
How to remove the race from hub on 92 geo tracker
so you took off a front wheel hub.
4wd car? or 2wd?
so you got the 150ft./lb nut ring off with out the special tool?
so how would you get the preload back right after?
RACE.
LIKE ALL serviceable hubs you use a 20 ton press.
http://www.fixkick.com/hubs/FW_BEARINGS.html#old
any machine shop, any suspension shop, any brake shop can to this
all shops worth salt have a press.
i walk i with 2 hubs and 2 bearing kits, and bam its in for $25
removing parts is easy, putting the back right ,that takes care.
Sep 20, 2014 | 1992 Geo Tracker
How to remove the abs ring on 1998 xj8
if it is a front ring remove front vertical link , you will see a spring locking device remove this a special tool is then needed to unscrew the abs ring if this is not availiable you try heating up the ring and using a drift, or drill down the side of the ring and splitting it with small chisel but you will need the special tool to fit the new one, they are TIGHTas they retain the hub bearing. if it is a rear one remove the rear hub carrier making sure you mark the track adjustment bolt to maintain rear wheel track. you should then be able to carefully remove the abs ring as it only trapped by the drive shaft, renew the hub nut
Mar 30, 2013 | 1998 Jaguar XJ8L
Removal of front right axle from a jaguar 2002 x-type
Loosen the wheel hub nut.
Remove the front road wheel and tire.
Remove the tie rod end retaining nut.
Using the special tool 204-192 Ball joint Splitter
detach the tie rod end.
Remove the subframe reinforcement plate retaining bolts.
Loosen the subframe rear mount bolt.
Loosen the subframe front mount bolt.
Remove and discard the wheel hub nut.
using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller
Detach the wheel knuckle.
Remove the lower arm ball joint retaining bolt.
Reposition the lower arm.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Install a new snap ring to the halfshaft.
Install a new halfshaft seal.
Remove the special tool.
Make sure the CV joint splines are located fully.
Do not use excessive force when engaging the CV joint into the link shaft.
Install the halfshaft.
Tighten to 25 Nm.
Attach the wheel knuckle.
Install the lower arm ball joint retaining bolt.
Tighten to 83 Nm.
Install the exhaust muffler inlet pipe.
Tighten the subframe front mount retaining bolt.
Tighten to 142 Nm.
Loosely install the subframe rear mount retaining bolt.
Install the subframe reinforcement plate retaining bolts.
Tighten to 35 Nm. Tighten to 142 Nm.
Install the tie rod end.
Tighten to 35 Nm.
Loosely install a new wheel hub nut.
Install the front road wheel and tire.
Tighten the wheel hub nut.
Tighten to 330 Nm.
Check the subframe alignment.
May 20, 2010 | 2002 Jaguar X-Type
1995 4x4 geo tracker front wheel bearings
first you remove the wheel then the break caliper then remove the locking hubs just remember to lay out the parts in order a special tool is called for but this job can be done without it you have to use a small cold chisel and a hammer to tap the large nut counter clockwise to remove, you can then remove the outer bearing and the rotor and hub assembly look on the back side reomve the bearing seal and inner bearing be sure to pack your new bearings with grease before you reassemble . takes less than an hour.
May 05, 2010 | 1995 Geo Tracker
How to replace lower left front ball joint ?
Removal & Installation NOTE This procedure requires the use of the following special tools: J 9519-E Lower Ball Joint Remover and Installer, J 34874 Booster Seal Remover/Installer, J 41435 Ball Joint Installer, J 45105-1 Ball Joint Flaring Adapter and J 45105-2 Receiver.
  1. On 4WD vehicles, remove the wheel center cap and drive axle nut.
  2. Raise and support the vehicle.
  3. Remove or disconnect the following:
    • Tire and wheel
    • Wheel hub and bearing, if necessary
    • Outer tie rod retaining nut
    • Out tie rod from the steering knuckle using a suitable puller
    • Brake hose bracket retaining bolts and bracket
    • Upper control arm-to-steering knuckle pinch bolt and nut
    • Upper control arm from the steering knuckle
    • Lower ball joint retaining nut
    • Steering knuckle from the lower control arm using a suitable ball joint removal tool
    • Steering knuckle from the vehicle
    • Lower ball joint flange with a chisel
  4. Install tools J 9519-E and J 34874 to the lower ball joint, then use those tools to remove the lower ball joint from the lower control arm.
To install:
  1. Install or connect the following:
    • Lower ball joint to the lower control arm, using tools J 9519-E, J 41435 and J 45105-2
  2. Remove the tools from the lower control arm.
    • Tools J 9519-E and J 45105-1 to the lower ball joint
  3. Flare the lower ball joint flange with J 9519-E and J 45105-1, then remove the tools from the lower ball joint.
    • Steering knuckle to the lower control arm
    • Lower ball joint retaining nut and tighten to 81 ft. lbs. (110 Nm)
    • Upper control arm to the steering knuckle
    • Upper control arm pinch bolt and nut and tighten to 30 ft. lbs. (41 Nm)
    • Brake hose bracket to the steering knuckle
    • Brake hose bracket retaining nuts and tighten to 7 ft. lbs. (10 Nm)
    • Outer tie rod to the steering knuckle
    • Outer tie rod retaining nut and tighten to 33 ft. lbs. (45 Nm)
    • Wheel hub and bearing, if removed
    • Tire and wheel
  4. Lower the vehicle
    • Drive axle nut, if 4WD, and tighten to 103 ft. lbs. (140 Nm)
    • Wheel center cap, if removed
  5. Check the front wheel alignment.
Nov 30, 2009 | 2002 Oldsmobile Bravada
Replacing front struts
Okay....here is the steps first....and then the directions on how to use the tools:
  1. Raise and properly support the vehicle.
  2. Remove the front wheel.
  3. Detach the shock absorber lower mount by removing the two bolts.
  4. Remove the retainer nut, retainer, cushion and shock absorber.
  5. Detach the cushion retainer from the shock absorber.
  6. Compress the coil spring with a commercially available spring compressor.
  7. Detach the stabilizer bar.
  8. Support the upper suspension arm and steering knuckle securely.
  9. Remove the cotter pin.
  10. Loosen and remove the nut.
  11. Using a ball joint removal tool, detach the lower ball joint from the lower control arm.
  12. Loosen the suspension arm set bolt.
  13. Remove the suspension arm set bolt nut.
  14. Remove the nut from the strut bar front set bolt.
  15. Pull out both set bolts.
  16. Remove the lower suspension arm and coil spring. To install:
  17. Installation is the reverse of removal. Note the following torque specifications:
    1. Strut bar front set bolt: 221 ft. lbs. (300 Nm)
    2. Lower suspension arm set bolt: 148 ft. lbs. (200 Nm)
    3. Lower ball joint nut: 80 ft. lbs. (110 Nm)
    4. Lug nuts: 83 ft. lbs. (110 Nm).
May 13, 2009 | 1998 Toyota Tacoma
Replace front outer unversal joints on front drive axel?
You need to remove the brake calipers, and wheel hubs; the nuts that retain the wheel hubs may require air impact to break them free (at least for me they did). Once you have removed the hubs, slide out the drive shafts. You will need a vise and a hammer beat out the old u-joints.
I tried to remove the wheel hub retaining nuts with a breaker bar, and cheater bar attached; it didn't work for me. I did have to use air impact on them. The job isn't that difficult "if you have the tools".
I hope this information helps you, and I wish you luck on your repair.
Apr 23, 2009 | 1998 Dodge Ram 1500 4WD
Cannot find tool to loosen front wheel bearing lock nut
I have a 1995 Geo Tracker 4WD with the same exact problem,However I did some research . You will need to go to the Kent Moore Website which makes specialty tools and look up Wheel bearing socket "J-37763" I saw the picture of it and it looks like there are 4 small rounded teeth/tabs. Unfortunately get ready to spend some money - cost is about $70.00 not including shipping/handling
I hope that this Info. helps - Jim H.
Apr 06, 2009 | 1995 Geo Tracker
Hand Tools Logo
799 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
