Looking for Hitachi 53UwX10BA service manual. Does anybody have one they can send? NoDevice does not have this one.
  • 10,594 Answers
Click HERE to download 53UWX10B service manual.
Posted on Feb 03, 2010
Testimonial: "Fast answer, and just what I was looking for. Thanks!"
  • Shahid Electronics
    Shahid Electronics Feb 03, 2010
    If above is not your required manual, check it out HERE, available for small fee.
HI ... ANY BODY HAVE LG CF21S14ET SERVICE MANUAL? PLZ SEND ME ikksanjeewa1991@gmail.com
try looking at this URL
http://www.nodevice.com/manual/LG.html
Jun 04, 2015 | LG Cell Phones
Hitachi 53uwx10ba service mode
are you using an HDMI cable? is it a cheap thin cable or heavy duty?
HDMI cables carry sound but it's possible you don't have it seated completely or it's a cheap cable. or your audio settings on your TV are not set to HDMI if that's the cable you're using. try running your audio setup on the TV Menu.
Dec 03, 2013 | Televison & Video
How do i get my hitachi 53uwx10ba into convergence mode?
This should be a menu option in the video portion or initial set up area of your menu. If you have auto converge it will do it for you otherwise it will put up a screen with color patterns for you to manually converge.
Sep 28, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA HDTV adjusting color
Hi, Your tv model has a small light blue color button inside for manual adjustmnet mode. You will have to remove the front covering below the screen. its just attached with velcrow. Then there will be a centre wooden pannel with the the switching box screwed to tv front with around six screws.Open this panel and look to the left corner of the chasis boards in front of a small metallic box. Thats the switch you have to press to get into manual adjustment mode. use remote to adjust the colors. once done press it again to exist. Visit www.fixurtvs.com to find out more about tv FAQs. Thanks if you found it helpful.
Apr 29, 2009 | Televison & Video
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
387 people viewed this question
Top Televison & Video Experts
