Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
How do i get the lamp out ..in order to replace it ?
  • 476 Answers
Frtom the front of the tv, go to the right and lower portion of the tv, you will find an access door, this door has one screw holding it in place, remove the screw and door, inside you'll see a black plastic cover that has two screws and a metal handle, remove the screws and pull the lever evenly, this will pull ot a cage, inside that cage you'll see the lamp. refer to the following link for replacement instructions. http://www.kewego.com/video/iLyROoafYw6f.html
Posted on Feb 03, 2010
Tip
DLP TV shuts down
If you find your DLP TV is shutting down intermittedly, it may be just a simple lamp gone bad. Follow your user guide to remove the lamp, check for visible damage or parts that have burst inside the lamp bulb itself, if so, go online to order a new lamp and replace it. Just enter your model number and the word "lamp" into the google search, order it and when it arrives, replace it the same way you took out the old one. Make sure you order the lamp "with housing" which is a little more expensive, but much easier to replace. Good luck!
Best Regards,
Beach TV Repair
Treasure Coast, FL
info@beachtvrepair.com
http://www.beachtvrepair.com
on Jul 05, 2010 | Audio Players & Recorders
JVC REPLACEMENT LAMP : HD-566787205
Please get the correct model number (one posted here has too many numbers--label is on back of set)
GOOGLE THE MODEL NUMBER WITH THE WORD "LAMP" AND YOU WILL FIND (if available) the lamp and several places selling it.
Mar 23, 2012 | JVC HD-52Z575 52" HDTV
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Lamp bulb replacment
much cheaper to do it yourself, go online put in your tv's model number and seach for thr lamp and make sure you order the entire lamp assembly, on the back of your tv there is a door open and take out old lamp so you know what you are ordering, and when replacing the new lamp amke sure not to touch the lamp
Aug 12, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I believe it'ds time to replace the bulb on my hlr6167w It is 4 years old. I took the 4 screws and thd removed the plastic backing. How do i removeve the bulb? I need to give best buy the bulb #
Look at the Lamp Module and you will see ONE gols colored screw. Remove that screw,then gently wiggle and pull out the Lamp Module. Look into the center of the lamp and you will see shattered glass or a white powder inside,If so replaced the lamp. The Lamp Code is located on the Left side of the set. It is a sticker labeled Lamp Code. Order a Lamp by this code. Replace the lamp in reverse order and reinstall the lamp Door with all four screws.
Apr 02, 2010 | Samsung HL-R6167W 61" HDTV
My Hitachi CP-X201 has a flashing red lamp light on & won't display. I replaced the lamp but it still doesn't work. WHat do I DO?
Hello :
Did you replace the lamp correctly ? If not , then i'll tell you how to do that :
Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
I hope this will help .
rate please !
If that wasn't helpful , then contact again please !
Mar 24, 2010 | Hitachi CP-X201 Projector
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Canon PC20 exposure lamp replacement
Back cover,left cover,and top cover.In that order.(Left cover opens with 2 clips.)Remove the glass.And then you can replace the Lamp.
Oct 31, 2008 | Office Equipment & Supplies
New replacement lamp ty-la 100rl not working
If you place order for Panasonic lamp again this time, I think you would not face this problem as in past you had no problem.
Sep 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
