Question about Goodman Heating & Cooling
Condensation building up in lower compartment of goodman 45btuh furnace in counterflow position 95%a.f.u.
  • 1,420 Answers
Make sure all drains and hoses are connected to the lowest positions and that they are free of any blockage or debris. If there is not a vent or stand pipe on the drain line as it exits the furnace cabinet, put one in. A stand pipe is a Tee with a vertical pipe going up approximately 5" and allows the water to drain easily by breaking the vacuum normally experienced by the inducer blower.
Posted on Feb 03, 2010
Condensation water drips from top of unit
I WOULD CHECK THAT YOUR PVC PIPING IS SEALED PROPERLY.
Feb 22, 2015 | Goodman Manufacturing GMVC951155DX 95%...
Tip
80%, 90%, and 95% Gas Furnace Manual
http://johnstonesupply9.com/TechDocs/Goodman/Furnaces/GMV9%20Variable%202-Stage%20Upflow%20Gas%20Furnace/GMV9%20Service%20Man.pdf
After giving up on Yahoo, I found this on Google. It's the detailed manual for 80%, 90%, and 95% gas furnaces. Hope this helps!
on Oct 04, 2009 | Goodman GMS90703BXA Heater
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
New furnace, Water In Induction Motor, Yellow Flame
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
Dec 23, 2013 | Goodman Manufacturing Goodman GCH950453BX...
Goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
The flame sensor needs to be cleaned. This video might help you understand how to clean the flame sensor.
Oct 05, 2012 | Goodman Manufacturing Goodman GMH950704CX...
My son has condensate building up in his flue and running down into the furnace. It is a 2 stage furnace. The contractor who installed it blames it on the chimney. Is that likely?
It is for sure a venting issue, depending on where you are located, it sounds like the local building code inspector was not involved for an inspecton of the furnace replacement. When the flue condensates like that, it is usually because the flue is the wrong size, usually to big,or it is dumped directly into a masonary chimney, and the chimney was not lined to the top.
I hope this answers your questions, please rate me and let me know if I can help further.
Sicerely,
Paul Gibson
May 13, 2010 | Goodman GMS90703BXA Heater
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
Water leaking out the bottom of my Furnace
One of the drain tubes (overflow) is plugged. Unhook each one and clear them of any debris.
Dec 20, 2009 | Goodman GMS90703BXA Heater
Goodman 90% gas heater condensation build up
If the exhaust comes off the top of the furnace, you will need to make sure the condensation will drain all the way back to the condensate outlet found at the base of the inducer blower. If you are having to remove the tube from the pressure switch, there must be a blockage from the inducer down to where ever it drains to. Check to see if all tubes are free of blockages and if there is a condensate trap, clean it out. If the pressure tube you mentioned is facing up toward the blower allowing water to flow into it, reposition it so water will not enter the tube.
Oct 17, 2007 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
112 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
