Question about HP L1955 19" LCD Monitor
I want to adjust my screen , its is streching vertically Please help
    Brigadier General:
  • 10,406 Answers
Look for "buttons" on the bottom-front or bottom-edge of the monitor.
One button will activate the OSD ("On Screen Display). Through the OSD, you can change the "vertical size" and "vertical position" of the display.
Posted on Feb 03, 2010
One inch of the window is off the screen
you could adjust the vertical and horizontal adjustment through the main menu of the monitor. buttons on front of monitor. auto adjust may fix it but if it does not look for the vertical or horizontal adjustment fot the area effected. if this helps please rate with comment
Feb 03, 2013 | LG Computers & Internet
Cs2047s with vertical fluctuating wave; part of picture streched rolling from bottom to top of screen.
it sounds like adjustments need to be made inside the tv itself.Or it could mean that the tube is about to go out good luck!!
Nov 23, 2010 | Mitsubishi Televison & Video
The Disks runs fine, never have any problems loading ANYTHING on it but when it loads PS1 Games the screen setting becomes quite odd. You dont see the whole screen (game screen) thus game play options dont...
It's not due to the compression at all. It's due to the limitations of the Snoy emulator. PS1 games output to 640×480 pixels (I'm using NTSC here, adjust if you live in PAL areas), but the PSP's screen is 480x272. In order to prevent weird streching, Sony desided to cut the screen size in half. So, the output of the ps1 emu is 320x240, exactly the same size that you see on your psp screen.
If you want to play with the streching, hit the home button, and under "Settings" you can adjust the screen size. Here is what the options do, as far as I know.
  • Fullscreen-changes the output full screen. "Letterboxes" (i.e., small black bars) it a bit to fit the 16x9 ratio.
  • Original-the 320x240 I just discribed above.
  • Normal-Streaches it a bit, and smooths out the picture
  • Zoom-Streches the picture even futher so that the width is equal to the width of the screen size.
Mind you, none of these modes ever make the emulator output a "better" picture with more pixels defined. They are all just streching of the 320x240 screen. I think this is because the psp is at it's limits, and rendering the extra pixels would lag the game too much.
Jan 03, 2010 | Video Game Consoles & Games
Normal and letterbox
"Normal" looks "streched" because the origin of the video is normal, so it gets streched. If you play a "letterboxed" material (may be a DVD) it comes compressed, (vertically streched) so when you play it in letterbox it streches up to the rigth aspect ratio. Take a look at it in wikipedia.
Jul 14, 2009 | LG 37LH40 37 in. LCD HDTV
CRT TV vert section
Vertical linearity is more of a DCV bias issue rather than feedback or AC coupling. Hence it would be more apt to suspect resistors rather than capacitors. Of course, it is also possible that the large IC that drives the Vertical output maybe at fault (least likely) but often would have trimpots for adjustment. Most current designs do away with trimpots and rely on self correcting (feedback loop) which is simply a resistor in the 100k range. In certain instances, it could be a thermistor or resistor or diode limiter attached to the yoke itself.
Best would be to use a service manual or at the very least a schematic diagram with voltage readings and compare actual on PCB against schematic.
If you could post back the make & model or preferably the chassis number of the TV, might be able to comment back known common vertical issues.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 05, 2008 | Televison & Video
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to know how to access the verticle hold to adjust TV
what do you mean that the picture streched out.this is a strange problem.as vertical problem does not strech it either have a line inthe middle of the raster, shrink both at the top and bottom of raster,lines run up and down on the raster.kindly explain your problem in detail then i will be able to help you.
Mar 19, 2007 | GE 31GT659 31" TV
Streched screeen!
I see more of this out in the field everyday. If you have a cable box or satelite receiver, then look for a format change on it. Usually in that components menu. If, you still cannot find the answer, reply back with the type of unit, if any, that control the channel on the set. I hope this helps.
Jan 12, 2007 | Hitachi C29-F800S 29" TV
Strecthed Picture
There is a problem in the Vertical sweep circuit. it could be a bad capacitor, a resistor that changed value or the vertical output IC.. These sets have no user replaceable parts inside of them as all the parts are soldered into place. If your not good with solid state brepairs, you will need to find a servicer to assist you with this repair. Good luck PS please do not forget to rate this.
Oct 14, 2006 | Goodmans 257NS 20" TV
HP L1955 19" LCD Monitor Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
