Question about Dishwashers
CDA CW497/1 - On, then off!!
When I turn the dishwasher on .. it sounds like it is starting the cycle, then after a few minutes it beeps and says it's finished! Any ideas please?!
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
daba2
  • 10 Answers
SOURCE: hoover dt999
E4 Error on other machines (eg. Baumatic) means that the bottom catch tray (condensate trap) below the machine has too much water in it. This condensate is supposed to evaporate away, but too much will mean it builds up over a period of time. There is a float that trips a microswitch in my Baumatic which detects this, it only needs 2 - 3mm of water before the microswitch is activated.
If this is the problem with your machine (try it annd see), there are several solutions posted in forums - best seems to be to remove plastic access hole caps from base and mop out the tray with sponge. TURN OFF AT MAINS BEFORE POKING AROUND INSIDE THE BASE. May have to repeat at regular intervals to.
What causes it ? - I think it is excess condensate from steam inside the wash cabinet, follow the manufacturers advice to open the door as soon as the wash cycle has ended to release as much steam as possible to stop it condensing inside the machine.
Peramnent solution ? - I don't think possible - My guess is it's just a bad design.
Dave
Posted on Oct 04, 2008
SOURCE: i have a cda mx194
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
Posted on Oct 29, 2008
SOURCE: Neff dishwasher sticks on 1 minute
We had this problem with our machine.
There turned out to be a few things that caused it:
- Firstly, the float assembly (an orange looking float in a little chamber, visible if you take off the left-hand panel of the machine) was clogged - we cleaned this and it seemed to help.
- The heat exchanger matrix was full of debris - we tried to clean this but ended up damaging it and bought a new one.
.. these two things seemed to improve the cleaning and the machine worked for a while.
The real problem though (which caused it to pump out continuously) turned out to be a failed seal on the circulation pump.
If you look on page 4 of the following link:
https://www.neff-eshop.com/eshop/neff/gb/prodp.htm?eShopType=S&prod=S5456X3GB%2f22
.. you will see a diagram of the bottom of the machine - the part that failed was 171598, which you can see on the bottom middle-to-right hand side of the picture..
The rubber had perished very badly, and it was causing water to leak into the bottom of the machine, which triggers 'flood mode' whereby it pumps continuously and doesn't actually wash the dishes.
The part costs about £5 - fitting it is not straightforward though, as you need to strip the machine down which is a pretty involved job.
If you think you're up to it, the steps I followed were:
- Remove both side panels
- On the left hand side, remove heat exchanger matrix and float assembly
- Remove kick-panel under the front door
- On the right hand side, remove all wiring from the door to the machine (including an earthing wire which is screwed to the side of the machine) - note that there are two wires which go to push-on connectors which have to be removed separately - all the others go to connector blocks.
- Inside the machine, remove the wire baskets, spray arm and bottom filter.
- Remove the lid from the salt dispenser - and now the tricky part, you need to find something that will allow you to remove the large plastic 'nut' that holds the salt dispenser to the machine.
- Remove the two screws in the bottom of the machine (167241 in the diagram mentioned above)
- Now, shut the door and then disconnect the door spring mechanism from the left and right side of the door.
- Disconnect the string from the door closing mechanism from the springs at the left and right back corners, under the machine.
- Remove the two screws at the back of the machine which connect the top of the machine to the base.
- Remove the two screws at the front of the machine which connect the top of the machine to the base (these are quite low down, near the door hinges).
Now, you should be able to lift the top of the machine off the base, and will have access to the pump etc.
... re-assembly is the reverse of disassembly ;-)
This took me a couple of hours - it might be better to find somebody who will do it for you for fixed cost as it's a pig of a job.
For what it's worth, there seemed to be very few places where the machine could leak - and this looked to be the major one - and there are a few push-fit pipes which are worth checking out too.
Hope this helps somebody.
Posted on Jan 07, 2009
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Posted on May 12, 2009
My cda cw496 dishwasher beeps in the middle of the cycle and then water leaks from the bottom. any suggestions?
The problem could well the plumbing past the machine... Are any of your other drains in the kitchen slow? A little snaking of the drain lines may be in order.
Jan 02, 2015 | CDA Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
It starts the cycle then it drains down and the bleeping starts saying theres a fault.
MAY BE A LEAK AND ITS ACTIVATING FLOOD SWITCH WHICH WIL DRAIN MACHINE TO STOP FURTHER LEAKS CHECK SEALS AND MOTOR SEALS FOR LEAKS
Jun 17, 2012 | CDA WC430 Dishwasher
Cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Apr 24, 2012 | Dishwashers
Cda 350 dishwasher
I have a cda cw195/1 integrated dishwasher, the red light stays on and when I attempt to start it the cycle begins then stops and it continually beeps, all the filters are clean and there are no blockages any ideas
Jan 14, 2012 | Dishwashers
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Dishwashers Logo
378 people viewed this question
Top Dishwashers Experts
