Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Whirlpool S/S Ref with Ice in Door - Mod # ED5FHEXMQ
My ice maker in my refrigerator started making a popping noise inside the mechanism. I went to the local repair store and bought a repair kit for it. My husband replaced it and nothing happened. My question is does the ice machine have to reach a certain temperature before the unit will allow water to be dispensed into the ice maker. If this does not sound like my problem, do you have any suggestions?
Thank you
    Problem Solver:
I have a whirlpool side by side. At first I coiuld not shut off the icemaker and it continued to make ice. Then it corrected itself for a while. The other day it started making ice and could not shut it off. I finnally was succesful in shutting it down and now it does not make ice.
Posted on Jun 13, 2008
  • 121 Answers
Most fridges run a defrost cycle 2 or 3 times a day. When this is happening a normal pop and sizzle sound will be heard. Otherwise I will need more information. Ice makers need to be cold enough to dispense ice, but not to fill. If yours will not fill, it may be the water filter.
Posted on Apr 21, 2008
How do I get my ice maker to work. It stopped making ice?
is there an arm inside that tells it when it's full if so lower the arm
Jan 24, 2015 | Whirlpool Refrigerators
I have a Whirlpool ED5FHEXMQ that has stopped making ice at all. The water dispenser works fine. I unplugged the appliance for about 20 minutes to try to reset the computer, but that did not work. The...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 22, 2011 | Whirlpool ED5FHEXMQ Side by Side...
Ice maker willnot make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 25, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
My ice maker stopped working totally.
there is an offspring on the door of your refrigerator, replace the rubber on the door of your refrigerator.
Mar 26, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Water leaks from ice maker and freezes next to fan.
Probably is the solenoid or dual valve ,thats leaking and the only way to fix this is changging the solenoid.
Aug 27, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Whilpool Side-by-Side ED5PHEXNQ00 Ice Maker Stopped Working. The "level" is down indicating that is needs more ice to fill the bucket, but the ice maker will not make more ice. I felt in the tray, but I...
There are 2 clips that hold the Ice plus on. 1 top left, and 1 on the right side.
Slightly pull up on the front of each clip and remove the controller. most likely behind this you will find a gear that is broken and may fall out of the unit. As usual you can not buy just the gear. Contact Whirlpool for the replacement gear assembly.
Feb 11, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Ice maker quit working
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Dec 15, 2007 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
