Question about Uniden Cordless Phone
I moved the phone and now the screen is blank, it will not boot up to the menu screen. I have tried unhooking the power and replugging. The phone itself works fine so no trouble on that part.
  • moorhousehou Feb 04, 2010
    thank you, I unplugged everything for about 1/2 hour then re-attached all and plugged it back in. Works like charm again!!
  • Uniden Master
  • 6,993 Answers
you need to go further by loosing the phone to check the flex/wire that's connects the screen to the phone main board. Some thing should be work internally, for the phone not to have displayed anything. It might have been shifted and not well fixed.
Probably if you leave it for some time, the screen might display again.
Take care.
Posted on Feb 03, 2010
My phones screen is blank how can i fix it ?!
You could try reseting your phone (do this by holding the volume up or down button, power button and the menu button all at the same time) do this until the service screen appears. If this doesn't work you could try the same thing only with just the power button and menu button.
Jul 01, 2014 | ZTE Cricket Score Android Muve Cell Phone...
I've had my (Compaq Presario SR2125UK computer for a few years now and have booted a fresh installation of vista from my boot menu 3 or 4 times now. All of a sudden when i hit esc to enter my boot menu, i...
your bios has a option for which GPU to boot 1st as more than 1 GPU is allowed. it may be a bit poor at determining gpu status if you havnt removed the add-on card yet.or if you have removed it and havnt set the default card option back. its the INIT 1st option which should have two choices onboard/pci-e. it needs setting back to onboard. to achieve this you may need to ERASE the CMOS. to do that disconnect power(yes and you must pull out the psu cable from the rear of the pc). wait 30 secs. take off the casing. Move across the JUMPER (near the battery)from MoRMal(NRM) to CLearR(CLR) wait for 15 secs. move the jumper back to NRM. refit the case. replug in the unit. start the pc and enter the BIOS. LOAD BIOS DEFAULTS and SAVE them(which needs a RESTART). it should be working now.
Sep 27, 2017 | Computers & Internet
Wont go into phone mode
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
Nov 10, 2011 | HTC EVO 4G Smartphone
When i turn on phone after android logo appears screen turns blank and phone will not turn off you have to take battery out
Try getting into recovery mode. Hold down home and press power. Keep holding home down while the phone boots. Can you get into recovery mode? You can just pull the battery after testing this.
You can also try holding "menu" while booting. This should put you in "safe" mode. If this works, then use the settings menu to do a factory reset and reboot.
Feb 26, 2010 | HTC G1 Smartphone
AMD Puma-based Asus M51Ta stalls at power up, screen is blank.
Have you tried booting and pressing F2 to get in the bios?
If that works you can check the boot devices and order of usage. Make sure the HDD is first.
Apart from that you can reboot and press F8 to get in the Windows boot menu, where you can try the Safe Mode.
If all this fails, the Windows configuration is somehow corrupt. You can try booting from a Windows CD and run the Repair option in the setup.
Oct 20, 2009 | ASUS M51Ta-X1 NoteBook
Computer does not boot
After replug the graphic card and switch on the pc & install back the graphic ... The power button remains green but the screen is black. ... From what i have noticed there is probably some issue with the thermal cutout ... Lights light up, Drive sounds as if working,
Jun 19, 2009 | Acer Aspire 1691WLMi Notebook
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Will not read HD & screen blank keep wanting to read th DVD drive can not find software when moving
try remove dvd drive, it can be broken, you can check your hdd via bios setup. On boot screen press F10, in bios menu - diagnostics, check hard drive
Apr 11, 2009 | HP Pavilion dv6000z Notebook
Unplugged insignia box replugged cannot access menu unit comes on
Plug the Insignia output to TV video 1. Turn on TV, set to video 1 source. Turn on Insigna. You should now have picture and be able to go through the set up again.
Dec 31, 2008 | Insignia Digital-to-Analog Converter for...
Uniden Cordless Phone Logo
73 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
