Question about Microsoft Computers & Internet
I have an internal and an external hard drive which have been corrupted. I 'think' the problem arose because I disconnected them while they were still active - yes, even the internal one because I was using a cassette type of carrier. The result is that they have between zero and 3 mb of directly addressable space. I have used many programs that will get back files under such circumstances with limited success. A lot of files are being returned as corrupted. I need some sort of software that could perhaps restore the drives and repair the files. The drives will not accept simple re-formati=ting. Any clues on this problem would be gratefully received. Regards, Peter Gomm.
  • 542 Answers
Have you tried the chkdsk /f command in command line. Most of the HDD errors can be repaired using this command. I also want to know that are you able to boot the system or not?
Eg: chkdsk /f c:
Revert back for more assistance.
Posted on Feb 03, 2010
  • Rajesh Pai
    Rajesh Pai Feb 10, 2010
    I have not got any update on the issue. If your problem got resolved, Please give your valuable feedback/rating for the solution provided.
Mac error 2066
Hi Taylor
I have been dealing with Mac's for over 20 years. Bought my first in 1984. The point being..... even if I gave you the description of the 2066 error, it would mean very little to you. It doesn't help.
It's more important to know which model you have, what OS (Operating System) you are running and what you were doing or what program you are running when the fault occurs!
Problems like your having do crop up, especially on Laptops because the internal hard drive gets bumped and corrupts data.
Depending on what data gets corrupted as to what the Error is.
Bottom line is, the machine needs some service about every 1-2 years to eliminate problems creeping in.
But.... You have a Mac.... So It's pretty straight forward really!
I have been using the following method for years.... SO.....
The best advice I could give you is....
Purchase an external 3.5" Hard Drive.(more robust than 2.5" pocket drives) About 1 TerraByte should do.
If you have a FireWire Port on your Mac then get a Hard Drive with a FireWire connector on the back... its faster,
Otherwise use the USB Port. (USB 3 Better)
Use the DiskUtility Program to Format the External Drive to Mac OS Extended (Journaled)...... Name the Drive something like "External Drive"........Now its ready for use.
Go on-line and download CCC (Carbon Copy Cloner)
(www.bombich.com/download.html)
Use this to make a Clone of your current Internal Hard Drive (Source in ccc) to the external Hard drive (Destination in ccc) This will take some time depending on size & content of your internal drive. Fifteen minutes to an hour.
Once completed, you should prove that the Clone is good by BOOTING from it. Restart & hold OPTION KEY DOWN & choose your new external drive. Once booted from external "Clone" you know for sure that the clone is a fully functional copy of your internal hard drive. Change the Desktop Picture in System Preferences so that it's different to your existing system. This is to avoid getting mixed up between Booted Systems (clones look the same)
The System Preferences / Startup Disk is also a useful tool here.
Now that you have a fully functional working bootable copy ("Clone") of your hard drive, you are SAFE from loosing any of your personal data. I make a new clone every few months to be Safe.
Now..... To rid yourself of all bugs & errors & faults and defragment your hard drive & update to a better (newer) version of the OS
ALL IN ONE HIT. and end up with a clean computer just like you originally bought. All you have to do is wipe your internal hard drive of everything. That is...ReFormat it with Disk Utility
(external drive unplugged for safety).
Then re INSTALL (takes about 20 minutes) a new clean (updated version) of the OSX. This is now free from Apple Downloads. e.g. OSX 9.1.2 (Maverics)
Then you can do one of 2 things.
Re enter all your details & passwords & Apple ID & Network details when prompted after re booting the new installed OSX OR
Choose Migration Assistant to put all of your stuff back in place like it was before you started. This usually works fine BUT it can put back faulty Apps etc that were causing problems before, so be choosy in what you put back (it allows you to select items)
Obviously it would be wise to have already downloaded the newest OSX for your Mac first. And even do a practice install on the external drive to see how the install process works.
FOR EXAMPLE
You could partition your new External Hard Drive into 2 Partitions of say 500GB each. One for your "CLONE" and one to experiment with the Install OSX Process.
You could even set up the New External Hard Drive with the New OSX e.g. OSX 9.1.2 (Maverics) first then "Migrate" all your old software back on to this drive. Boot the drive & test it for faults etc. Try for a couple of days. Then Re Clone it with CCC back to your Internal Hard Drive for permanent daily use.
It's up to you.... But having an external CLONE gives you so many advantages. You are using Apple Technology and ease of use here! So it's easy to do all this. Think yourself lucky, PC People would very rarely consider doing this with Windoz because it's just too difficult!
Good Luck
Trevor
Jul 14, 2014 | Computers & Internet
Siig sc-sat212-s4, stops boot when connected
While most computers are capable of starting up properly with external drives connected, from time to time the external drive can cause confusion during the startup process. The computer may attempt to boot from the external hard drive rather than the primary internal drive. This causes the computer to fail during startup because the external hard drive does not have the operating system installed on it.
Disconnect the external hard drive from the computer. In order to minimize the risk of damage to or loss of files on the external drive, shut down the computer if possible, or hold down the power button on the computer until the computer turns off and then disconnect the external hard drive. Restart the computer with the drive disconnected. If the computer still does not start up, it is possible that the computer is attempting to boot from the external drive. Reconnect the external drive and restart the computer. Watch the screen as the computer boots up. A prompt will appear indicating which key to press to enter "Setup" or the "BIOS." Press this key when the prompt appears. On many computers the key is either Delete ,F2 or F10. Use the keyboard of the computer to navigate the "Setup menu" that appears. (Advanced Bios Features.) The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? or using the arrow keys you can load failsafe or optimized defaults this will set the boot order. Highlight the option for "Boot Disk" or "Startup disk" and select the "C:/" or the primary internal hard drive. Press the associated key, labeled so on the bottom of the screen, to save the changes and restart the computer. This will allow the computer to boot from the appropriate drive. Hope it helps.
b>
Jan 23, 2013 | SIIG Scsat212s4 Pci Serial Ata 2 Channel...
Verbatim clon 320gb is corrupt and i can not do anything with it
Open the case of the external and get the HD out you can then hook it into a pc internally as if was an internal hd (did this when my external HD was failing)
Dec 12, 2011 | Verbatim Smartdisk Clon Portable 97061...
My lenovo z61m computer is going to sleep every three minutes when the above message appears. this problem started when I started using a 500 GB toshiba external hard drive
disconnect the external drive and see if it still happens. If it does, the timing may be coincidence...check the main hard disk for bad sectors.
If this solves the problem, have the external drive checked for bad sectors.
Also with the external drive disconnected, open up a command prompt (or go START, RUN) and type sfc /scannow
this will check the system files for errors and replace any corrupted ones.
NOTE: you will need you OS CD when you go to do this.
Feb 22, 2011 | Computers & Internet
My computer says it does not recognize the external hard drive after i have used it for several months. If i use it on another computer, will it recognize it or should i download something first?
Install the hdd in another PC, If run well,think your OS has corrupted.
Then you should re install the OS again.Or you can restore the system
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the HDD is not run run in that another pc ,think external hard drive, has damaged and should change.
Hope it will help you.
Dec 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Internal hard drive
They do make cases that you can buy to turn an internal HD into an external. Best Buy I think sells them.
Dec 19, 2009 | Seagate 160GB 3.5" External USB Drive 160...
Keep getting blue screen, then directed to Microsoft site stating a hard drive problem
Blues screens are one of two things,
1) Corrupt bios - 'what starts up your PC'
2) Bad section of your hard drive - Can fully wipe off your drive with a Software program and start from scratch. when you do, the software will write over the bad sector or around it.
3) Drives are getting less expensive to replace - you just may think of replaceing it and reloading your operating system and start from scratch.
4) Then by USB external 2.5 cabinet 'Under $12.00' at Microcenter or Best buy and place the old drive in the portable/external cabinet to transfer all your old files over to the newer much larger internal hard drive.
Just a thought -
Blessings,
A/V Media Guy
Nov 21, 2009 | IBM ThinkPad T41 2373 Notebook
How to remove the internal hard drive
enter in bios and disable ide or sata on which your harddrive detectd.
then simply install win xp in external usb harddrive.
Jan 04, 2009 | Toshiba Tecra M7 Tablet PC
Acomdata slow to be read by my computers
What operating system are you using? Have you tried this external HD on any other computers since the problem arose?
I'm thinking it's a corrupted device identifier, but can't make a suggestion until the questions above are answered.
Mar 17, 2008 | Computers & Internet
Putting together and external HD
You purchased a SATA hard drive. Your enclosure is probably meant for an IDE hard drive. If you can, return the SATA hard drive and exchange it for an IDE hard drive.
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
