Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
TV makes a humming sound and the picture won't turn on. I get sound for like 30 seconds and then the tv shuts off and I get a light bulb and exclamation point on the front!
    Master:
  • 406 Answers
The lamp is bad change it. The problem would be solved. 95% sure.
Posted on Feb 03, 2010
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
PROBLEM WITH SAMSUNG DLP TV
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Shuts off after 30 seconds of Play
is the set still under warranty,if so call for service if not when you turn it on try to listen near the side of the unit for a fan noise or high voltage arc sound and do you see light on the screen or in the rear of set.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Jerry Greenberg
Jerry Greenberg
