Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
U-line UC02175 water inside pooling under veg drawer, icemaker supply turned off, no water in catch pan inside back
  • 93 Answers
Well sounds like your ice maker evaporator drain hole is frozen, every time the unit goes into defrost cycle, water backs up and leaks down to the drawer. You can try turn off the refer for 48hrs with the doors open, most case it will reset by it self. If it is happening again in few weeks, then you evaporator drain pan heater is not working. Also make sure the doors are shut all the time.
Posted on Mar 02, 2010
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Water is pooling under the veg/fruit drawers..cant tell where its from. Freezer temp is uneffected, temp appears fine, no condensation anywhere on refrig or contents...The first I noticed it was a week...
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
Feb 17, 2011 | GE J Series 20.6 cu. ft. Top Freezer...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Water drain
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 24, 2009 | Refrigerators
Water leaking from freezer
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle.
May 18, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Jul 08, 2008 | Refrigerators
Refrigerators Logo
131 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
