Question about Fisher Paykel EcoSmart GWL15
Fisher paykel washer wont spin
The washer washes but wont spin out the water, I have tried unplugging the machine to reset but it does the same thing will wash but when it comes to drain the water out & spin it wont, so now it is sitting there full of water, I have removed all the clothes and check the hose that fits in the wall pipes(drain) and nothing is plugged I can blow air into it, and it bubbles in the tub filled with water??? What do I do, can you help? Any suggestions?
  • 3 more comments
  • Anonymous Mar 07, 2008
    I have exactly the same problem will wash but wont spin has done it once before and blew in end and it worked
  • karenjane Apr 07, 2008
    I have a fisher and paykel.  When it comes to the rinse and spin mode the machine just stops.  It sounds like it wants to spin and let the water out but it does not do it.  It goes through the whole wash cycle and then stops.  Please does anyone have suggestions...  It has been 5 days..  Thanks, Jane
  • autstone Jan 08, 2009
    My washer went through all the wash cycles and it stared beeping so i turned if off and turned it on again and went to rinse cycle and it makes this quiet humming noise like it wants to do something but of course it's not. Went to spinning cycle also to see if it would work and it didn't. Will go through the was cycles as many times as i want but not the rinse or spin.
  • Barb in Minn Jan 11, 2009
    I also experienced problem with my Fisher & Paykel washer getting stuck when it reached rinse mode. After reading advice to check diverter valve, I found this helpful video, walking through diagnostic and repair of diverter valve.
    http://www.youtube.com/watch?v=JfJ1ZD4CV...
    Useful to learn that list of diagnostic codes is available on a piece of paper hidden underneath the control panel.
    In my case, I realized that there was probably ice somewhere in the drainage system. (sub-zero temps here in the Minnesota this week, washer is in cellar - i.e. has outdoor entrance instead of through interior). Running space heater overnight solved problem.
  • Anonymous Mar 15, 2014
    works in the first wash, water drains, but the washer wont spin
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 21, 2008
I gave both solutions a fix-ya because the hose from the pump to the diverter was totally clogged with dirt. It was easy to remove the hose and clean and within ten minutes it was like we have a new washer(Fisher & Paykel GWL15). Thanks to both of you!
Steve
Posted on Mar 23, 2008
  • 125 Answers
The diverter valve is probably broken, check under the machine, follow the black hose from the pump to the diverter valve, check the elbow on the end of the wax motor to see if its broken, if it is replace the diverter, no tools required.
Posted on Mar 20, 2008
    New Friend:
I had a similar problem. Decided to try to check pump and outlet hose, but could not work out how to do it from these posts. The "Inspection Hatch" is almost useless - yes I can see the Water Pump, but that's about it. The hose runs out the back of the water pump then up to where it exits the machine housing (back top left corner). I managed to find a Service Manual online (http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf) and used this to complete the job. Machine back together, but it was a BIG job - Lid & machine top off, Manually empty water, Inner bowl out (really difficult since machine 20yo & drive spline did NOT want to come off - or go back on)...finally inspect top of pump. Very difficult to get to hose without upending machine! So I rigged up a hose and blasted water through the outlet near the pump in the bottom of the outer wash bowl.
This job was fiddly and took hours, but very do-able if you can read a manual, use a screw driver and have some trouble-shooting & problem-solving skills. Very satisfying when the machine 1. Still worked! 2. Emties water.
Posted on Jan 08, 2014
  • Nadine
    Nadine Jan 09, 2014
    Oh, I found fur/hair/muck, a safety pin and a wire from an under wire bra around the top of the pump (in particular the impellor) - would have been there years! Also a reasonable amount of much was blasted out of the hose.
I had the same problem...pulled pump and discovered a plastic collar insert from one of my dress shirts was lodged in the pump.
TLeo
Posted on Oct 13, 2008
3 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Posted on Sep 07, 2009
Water drains during wash cycle
A couple things to check, is it actually turning on the drain pump? Is the water valve leaking by?
Apr 10, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher & paykel smart drive 051 will wash then drain, but when it gets to the spin cycle it wont spin at all it fills then drains only.
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
My fisher pakel washer is stuck in regular wash, low water level. It sounds like the motor is emptying but it never goes to spin. I tried unplugging it to reset the computer but it always goes back to the...
Hi just just read your posting,Now have you tried selecting a different cycle and water level?Could you please confirm the model number of your machine for me.Is the machine draining the water out of the bowl? Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
Hi Dale..
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing machine faulty
needs a new pump and control maybe, its the most common sollution for that problem
Jan 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
9,246 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
