Question about Kenmore 24032\24036 Top Load Washer
How to remove agiator part from washing machineh
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Generally, at the top of the agitator, there is a plastic cap which will unscrew. This cap covers a large NUT which, when unscrewed, lets the agitator be removed.
However, be aware, the NUT is heavily torqued and a real B**** to remove, especially since the agitator needs to be securely held to prevent movement. Then, the agitator itself needs to be forcibly removed, and a special tool, which looks something like an oversized gear puller, is needed to pull the agitator UP and off the spindle. This spindle goes through a seal and a bearing, and has a pulley on the end which is turned by a belt which also goes around a pulley on the TRANSMISSION, which basically is responsible for 'shifting gears' between the agitate and spin cycles. Good Luck!
Posted on Feb 03, 2010
How to pull plastic pice after take off the agiater an the four screw magic chef oil is comeing up tub when washing
These require a special spline tool and spring compression tool to remove the tubs... not a do-it- yourself job.
Apr 26, 2016 | Magic Chef Washing Machines
Kenmore washer 80 series will not agiate
What is the model number of your unit?
Nov 25, 2012 | Washing Machines
Not spinning on large loads
tightened down agiatator or replace agiatator.
Jul 21, 2012 | Kenmore Washing Machines
How to remove agiatator
Here is a video to show you how to remove the agitator.
Happy Holidays The FixYa Team
Dec 25, 2010 | Whirlpool Washing Machines
Washer will not agiatate, makes funny noise, will not spin
transmission sounds like its gone bad, will it spin, if it does it mite be ur timer
May 22, 2010 | Whirlpool Washing Machines
Washer will not drain.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Trying to remove agiator, flat across thae top -
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following illustrated description of how to remove agitator(s)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=329f760a99d92f01a1ba376753d0d4fc
Some washers use a 1/2" plastic nut to hold the agitator in place.
I've found that using a 1/2" extension for a socket set works very well.
Dec 07, 2009 | Kenmore 24032\24036 Top Load Washer
WEAK AGIATOR
Does the agitator shaft turn real easy or does it stop or keep from turning 360. It should have limits and not free wheel or turn around and around. Does it spin correctly? Most generally the parts you are looking for would be accessed from beneath the unit. Not sure about what dog ears are but there are plastic pieces that make the unit shift from agitate to spin on some models. If it has slight resistance to turning the agitator shaft but will turn 360 the gear in the transmission is probably stripped out. Do a little looking from the bottom and turn the shaft while looking at the bottom to see if you can tell what is out. You might find broken parts on the floor under the machine...
Feb 10, 2008 | Washing Machines
Knocking sound in agitator
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
120 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
