Question about GE Profile WPSR3120WWW
Machine stuck in spin cycle what is problem - GE Profile WPSR3120WWW
  • 129 Answers
Timer
Posted on Feb 04, 2010
Not drain/no spin
If the machine doesn't pump out, it wont spin. Make sure the machine isn't on a "drip dry" setting. This will stop it from pumping and spinning. Have a look for foreign objects stuck in the pump or hoses.
Sep 17, 2015 | Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
How can I find out if there is something stuck in the machine. Things still wet after spin.
It could be two problems. Check the hot and cold water inlet valves, it should be completely close at the final spinning cycle. Another thing is water outlet pump it should be run on the spinning cycle. Something might be stuck in the water pump.
Feb 01, 2015 | Washing Machines
Washing machine gets stuck in the rinse cycle
try cleaning the valve filter on the cold inlet
Apr 21, 2012 | Washing Machines
Cycle stuck on 23 minutes and keep repeating cycle
If you do a Spin Only cycle with that wash load will the machine Spin up?
If not any error code?
Does the wash Tub bang around with a Spin Only cycle?
Do you want to DIY the fix or call in a repair service?
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Maytag LAT9356AAE drive pulley stuck during spin cycle
I had the same problem called a repair guy who told me the transmission is ceased up and the main bearing and seal is shot. Told me that Maytag uses defective parts in their machines and recommended direct-drive washer. Repair would cost more than to buy new. Sorry!
Nov 09, 2007 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
