Question about Nintendo Super NES Console
Super Nintendo won't show any picture or sound even though it reads a signal.
My Super Nintendo turns on normally but i can't get the game to show up on the TV. It was working fine last nite when i played it but when i went to use it today nothing.
  • brandenstone Jan 13, 2009
    same problem with mine it turns on and everything and the screen goes completely black as if the game is about to come on but it doesn't show picture or sound i just played batman forever today and then it just stopped after that durning the game it the screen went black........does it need to be cleaned or something??is that one problem that could be wrong with it don't they have a cleaner one that is in the shape as a super nintendo game??
  • 43 Answers
Try pushing down and back lightly on the cartridge while turning it on.Used to work for me.You can also clean the game contacts with rubbing alcohol.Hope this helps...
Posted on Feb 21, 2008
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
Super nintendo turns on but not picture or sound
if you've tried 2 other super nes' and still no picture and sound.. don't you think it's the "yellow,red,white" cables that might be an issue? doesn't sound like a power cord is the issue at all if it's getting power to the "red light".... get a new y,r,w cable (sry.. tired and forget the name)
Sep 25, 2009 | Nintendo Video Game Consoles & Games
Game shows as loaded on the home menu screen but won't play.
It is because you need to do the following things:
unplgg the wii consol.
Then wait 10 minutes.
Plug back up.
Then if still shows call nintendo
Aug 29, 2009 | Nintendo Wii Console
I have turn on the super nintendo but nothing happens my t.v. screen just goes to a black screen, the power is on and I have change the cord, is it possible that they system itself have finally give in?
if you can't even get the main screen of "Nintendo" to show up then it probably is a problem with the video cable. make sure the cable ends and the ports on the tv and consle are clean and connected properly. if that doesn't work then the cable is defaulty or the system isn't putting out a signal.
Jul 31, 2009 | Nintendo Super NES Console
Extensively tested but unresponsive SNES controllers
Well it could be the controllers but its probably that one of the wires have gone bad in the super nintendo. Maybe try replacing. Just and idea though.
Mar 24, 2009 | Nintendo Super NES Console
In Super Mario Bros Nintendo DS The last castle in World 8
Try to move around, if you cannot keep turning the game off.
Nov 24, 2008 | Nintendo New Super Mario Bros. for DS
SNES Sound but no Picture
either the wires could be shot or to an nes the same wires work but sometimes cause errors
Sep 18, 2008 | Nintendo Super NES Console
Super smash brothers brawl on wii
OK it took a while for me to notice this but the disk has to face a certain direction or the disk won't be read... Sorry if this isn't helpful... but you can have a picture of hinata! and some pokemon thing!15061ee.jpg9b5edd6.gif ( P.S HE HE I am a girl! :P :) )
Aug 16, 2008 | Nintendo Wii Console
Connecting super nintendo
well if the other end is three colored plugs then plug it in the video in and audio in rca plugs and if it's a cable plug hook it uo there
Feb 19, 2008 | Nintendo Super NES Console
COnsole trouble for SNES
The old school gamer. :-)  Love it.  The plow in the bottom of the game.  Then try.  This normally works :-)
Oct 22, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
467 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
