Question about Kenmore Oasis HE 27082 Top Load Washer
Can I open the back of the machine and reset if I get a F error code. I even have a service contract and they can not get out to service for a week
  • 39 Answers
Unplug the machine and let it sit turned off for 5 min. Re plug in and see if it works. If still have F code error you will have to wait for service to fix problem. There is nothing you can reset.
Posted on Feb 03, 2010
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
CANON IMAGECLASS MF 7460 CODE E000007. HOW DO I RESET THIS MACHINE.
Its because of Fixing film assembly failure its not solving resetting the machine you need to replace fixing film assy
Feb 07, 2013 | Canon imageCLASS D780 All-In-One Laser...
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
Ir6000 error code e246-0002
fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Apr 03, 2008 | Office Equipment & Supplies
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
System Error E000
Since there are few techs who can function on telepathy alone, a make and model number is mandatory.
Make; model #; description of problem, and it wouldn't hurt to mention (generally) where you are located.
There isn't a 'generic problem' within even a particular manufacturer's machines; most have varying sets of error codes within series of machines since they may be equipped differently.
Jan 25, 2008 | Office Equipment & Supplies
System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Jan 14, 2008 | Canon ImageClass D880 Copier
Printer Code and Power Failure Error
the machine memory is hung
try this
press Function 7 monitor(4 times) *
service mode is appear
scroll down.. select Ram initialize select all job clear.. if the problem still there.. repeat the procedure but instead of all job clear.. select the Flash memory clear.. found it after all job clear mode
Oct 29, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Kenmore Oasis HE 27082 Top Load Washer Logo
109 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
